Here’s another thought. Shoes used with SPD pedals (and MTB shoes in general) are supposed to have those rubber lugs on both sides of the cleat. They contact the pedal body and help stabilize the shoe. If your shoes don’t have this, maybe that’s what is causing your squeaking, or at least making it worse.
Here is an adapter to convert road shoes to MTB. It includes the logs that I am talking about. Just make sure that you trim them if necessary to keep them from contacting the Assioma pod.
@huges84 I don’t know about other people’s experiences, but I found that those adapters did not last: the rubber lugs / edges just wore away after a short time [a month or two].
The fact that the pedals don’t spin freely would concern me. It’s probably introducing a fair amount of friction, which means the power meter is going to read low. The question is how much effect it has.
It would be nice if you could compare to another power meter and share the results.
Looks like your instincts were right. I was watching the power numbers yesterday during my ride. It wasn’t the most controlled or scientific test since my first priority was just to enjoy myself. Also, this was a first ride with a new brake/rotor set with a bit of pad drag going on on the front wheel.
Having said all that, the crank and pedal spindle power numbers were about the same during light pedaling at 150 watts. However, there was a noticeable difference as my power went up over 200 watts. At 300+ watts, I was observing a consistent and repeatable deficit of 25-30 watts at the crank vs the pedal spindles. I didn’t notice this kind of difference when I was running the TRVS Duo pedals.
So yes, the wellgo M194 pedals work and are much closer to proper flat pedals, but that’s a fair amount of wasted power. That puts me in a tough position. The Duo pedals really aren’t fit for purpose for technical MTB riding and these seem to be throwing away at least some power when I need it most.
Hopefully somebody will find a better flat pedal fit for technical MTB that plays nicely with Assiomas.
I’ve started using the Xpedo CXRs in anticipation of doing this hack, and their cleats as well. Through the pedal stroke I feel a decent amount of play up and down (x axis), especially at the top of the stroke when I’m pulling up. I’ve checked and everything is tight, is this normal?
Re: Flash 2 vs Flash 3 - The pedal came with a spindle bearing the III of the Flash 3 which appears to be the only easily visible difference when I look at the ISSI website. Obviously, I removed the ISSI spindle.
I’m not talking about the ISSI Flash II vs Flash III. I’m talking about the ISSI 2 Triple vs ISSI Flash III. I’ve attached two pictures below, the ISSI 2 Triple is the unmounted pedal, the ISSI Flash III is the one mounted on a crank.
From the side of the pedal the difference is pretty obvious. From the top however, I’m not quite certain how to distinguish them.
Hehe, well, great news for me though, since being in Europe I’d have to import the ISSI Flash III from the USA, whereas there seems to be some old stock ISSI 2 Triple still for sale over here.
For those looking for a flat pedal solution, perhaps you could use one of these converters to get something useful. It’s not going to be the thinnest solution, but it’s something.
So I found a flat pedal that’s not perfect from a platform perspective, but is solid for fitment. Was looking around Amazon for 3 bearing setups gauging the spindle length by photos and tried this. https://smile.amazon.com/dp/B06XRZD75T
Kinda a small platform even excluding the module size impact, but the pegs are replaceable, length is perfect, no free play or wobble, and just the right amount of space between the pedal and the module. I do not have another power meter to compare, I wanted to start using one with a fat bike and this seemed like the most flexible option. I’ll probably keep an eye out for other options still including suggestions in this thread, but if anyone needs a flat pedal option this will do.
