You get faster when hard days count and easy days let you recover, adapt, and improve. TrainerRoad AI’s Fatigue Detection gives you a live view of when recovery is needed, so you can avoid overreaching, stay consistent, and keep fitness moving in the right direction. It builds on the past Fatigue Detection model and works inside your 4 week Training Simulation Window to show how today’s choices shape tomorrow’s training and recovery needs.
What Fatigue Detection is
Fatigue Detection both detects and predicts training fatigue based on your riding, fitness, and schedule. When recovery is needed, it schedules recovery days and adjusts upcoming sessions so your plan stays productive. You see these changes in real time on your Calendar inside the 4 week window, alongside Predicted Workout Difficulty and Live AI FTP Prediction.
In short: it tells you when to ease off, how the next few weeks shake out, and what that means for your future FTP.
Adaptive Training
Get the right workout, every time with training that adapts to you.
Check Out TrainerRoad
What it Feels Like to Use Fatigue Detection
  1. Open the app
    Your next workout is waiting, matched to your fitness and recovery needs. A quick glance at the 4 week window shows predicted difficulty for the week, where recovery days land, and where your FTP is trending.
  2. Train with confidence
    If the system predicts you can handle a harder step, you will see it. If it detects or predicts training fatigue, it schedules recovery days so you can recover, adapt and get faster. You ride without second-guessing.
  3. Watch the plan adjust
    Finish the session or make a change and TrainerRoad AI re-simulates instantly. Recovery needs update, future workouts adjust, and your projected FTP refreshes, so you always know what is coming and why.
How Fatigue Detection Works for You
You add a big group ride
Replace the planned workout with your group ride. Fatigue Detection reads the added load, updates recovery needs, and reshapes the next few weeks so you stay on track for your goals.
You do too much on the weekend
Fatigue Detection reviews the rides, updating recovery needs, and reshaping the next few days so you can recover, adapt, and improve. The 4 week window shows how these choices move your projected FTP and future recovery needs.
You’ve had a stressful week
Fatigue Detection sees how you have been rating your rides and the alternates you chose. From that data, Fatigue Detection can make small adjustments to keep your training productive. It doesn’t just tell you when to rest, it adjusts your workouts so you can train consistently and reach your goals.
You want to push a key interval day
You can pick a harder alternate workout, if you are feeling up to it. Once added you can see how it will affect your future training and recovery needs. It may cause more recovery needs in the future and reduce your progress overall, letting you see if it’s worth it or not.
Adaptive Training
How Fatigue Detection Helps You Better Prepare
  • Fewer surprises: you know when recovery is needed before fatigue derails a week.
  • Better planning: the 4 week view shows how changes ripple forward, so edits feel safe and informed.
  • Higher quality key sessions: recovery days clear space for key sessions, which allow you to be more consistent and make greater improvements.
Why it Leads to Better Results
Fatigue Detection helps you do the right dose at the right time, then recover to adapt and improve. Athletes using TrainerRoad AI are seeing more power PRs, fewer failed workouts, and fewer days that feel too easy, because training remains productive and sustainable across weeks, not just days. Steadier training and smart recovery are what lift fitness and FTP.
Tips to get the most out of Fatigue Detection
  • Review the 4 week window, then ride: check recovery days, predicted difficulty, and your FTP trend.
  • Respect recovery days: recover days let your body adapt, and improve—making the next key session counts.
  • Plan big rides intentionally: add outside rides, then watch how Fatigue Detection reshapes the next weeks to keep progress moving. See what the best way forward is.
Let  TrainerRoad AI handle recovery planning so you can focus on riding. That is how you turn consistent work into real fitness and more PRs.
Learn More About TrainerRoad AI Features:
