NEW! | How to Predict Your FTP with TrainerRoad | AI FTP Prediction | TrainerRoad AI
What Is AI FTP Prediction?
Training is a long-term process, and progress does not always show up right away.
AI FTP Detection got some big updates and now has even better accuracy, adjusting to meet you where you’re at more quickly than before. But that’s not all!
Instead of guessing or waiting for your next FTP update, TrainerRoad’s new AI FTP Prediction shows you where your FTP is expected to be once every 28 days based on your current training. It is a live forecast of where your FTP is trending based on your training, so you can train with confidence and clarity.
See the direction your fitness is trending before you even get on the bike.
For every training block inside the AI Training Simulation window, TrainerRoad AI:
- 🔮Forecasts where your FTP is expected to land based on your current training.
- 🔄 Updates that prediction automatically as your training changes.
- 🧭 Gives you a clear view of how today’s work contributes to future progress.
Adaptive Training
Check Out TrainerRoadSo What Is It Like To Use?
When you get your first AI FTP Detection/AI FTP Prediction with the new model, your FTP can be different from what you’re used to. But the actual wattage of your workouts will be very similar and will progress similar to how they do now.
The result of this new FTP is a functional data driven benchmark for training, that is built to improve performance. The actual wattage of your workouts will be very similar and will progress similar to how they do now. You should not see a massive, sudden dip or jump in workout difficulty with the FTP change.
Open the app
You see your current FTP and your future AI FTP Prediction on your Calendar. It shows where your training is expected to take you next.
See what’s ahead
You glance at the 4-week window to understand how upcoming workouts, recovery days, and training load shape your projected fitness. You can see progress forming before it happens.
Train with intention
As you complete workouts, skip sessions, or adjust your calendar, the prediction updates in real time. You can see how those decisions may impact your progress and adjust thoughtfully.
Train, adapt, improve
TrainerRoad AI continuously recalculates your training. As your plan evolves, your AI FTP Prediction evolves with it, keeping your training aligned with your goals.
Visibility Without Pressure
AI FTP Prediction is designed to guide you, not to pressure you.
It does not replace AI FTP Detection. Instead, it shows you what your current training is building toward so you can stay confident in the process.
If your training stays consistent and productive, you will often see that reflected in your prediction. If training changes, the prediction adjusts to reflect that too.
How AI FTP Prediction Helps You Train Smarter
Understanding changes
If you move, skip, or swap a workout and your FTP Prediction updates, that simply means TrainerRoad AI is recalculating your trajectory based on your updated training.
Planning ahead
Seeing how your fitness may evolve makes it easier to plan training blocks, recovery, and life commitments with confidence.
Staying on track
AI FTP Prediction reinforces steady, sustainable progress rather than chasing numbers or forcing changes before your body is ready.
Adaptive Training
Check Out TrainerRoadWhat is TrainerRoad AI Doing To Predict My FTP?
TrainerRoad AI only sees raw power, heart rate, and RPE; it then figures out the next best wattage for you in your workouts to keep you progressing. It does this by running hundreds of training simulations to find what will improve your performance the most. After that, TrainerRoad AI translates those watts back into FTP and workout levels for you to use and understand.
The result of this new FTP is a functional data-driven benchmark for training that is built to improve performance. When accepting your new FTP, you shouldn’t see a massive, sudden dip or jump in workout difficulty. The actual wattage of your workouts will be very similar and will progress similarly.
- Check out this article if you want to dig deeper into the New AI FTP Detection
- TrainerRoad AI FTP Prediction FAQs
Train With Clarity, Not Guesswork
AI FTP Prediction helps you understand your progress before it shows up as a new FTP.
When you can see where your training is headed, it is easier to stay consistent, make informed decisions, and trust the process.
Train with confidence and let TrainerRoad AI show you the path forward.
How to Get Started
Head over to TrainerRoad.com and start exploring TrainerRoad AI today.
“Early adopter can confidently say it’s the best training app out there.“
All for a Fraction of the Cost!
Traditional coaching can cost hundreds of dollars each month. TrainerRoad gives you all-in-one access to AI-driven training, personalized planning, AI FTP Prediction, fatigue management, and deep performance analytics, all for a simple, affordable monthly or annual price.
Learn More About TrainerRoad AI Features:
- TrainerRoad AI
- AI Training Simulation
- A Data Driven Explanation of the New AI FTP Detection
- Predicted Workout Difficulty
- Improved Fatigue Detection
- TrainerRoad AI Workouts
- Training Approach
- Dynamic Endurance
- AI Workout Alternates
