I have to seem a problem with the Android version of Zwift.
In PC i get the synced workout from TrainerRoad calender, but on my tablet I don’t see it in either the “for you” or under the “custom workout” folder.
Is there any workaround or fix?
Out of curiosity, is your tablet updated to its most current OS version? And does it have the most recent version of Zwift?
Just checked, everything is up to date.
Even forcing a sync over PC, the workout doesn’t show on the tablet.
Personal custom workouts do though.
Update:
Ist seems to sync now when I just minimize the Trainerroad App beforehand, when I close it before opening Zwift, then it doesn’t show up. Seems like a weird behavior.
I have a 1st generation kickr and did an endurance ride with TR in Zwift but also kept track of the power outputs with my Garmin Vector3 pedals. Unfortunately, the correlation was not very good. After the warmup, to get the workout power to match up with the pedals, I had to bump the workout intensity by 10%. As the workout progressed, I had to keep reducing the workout intensity to keep the power batched. By the final interval, the match was achieved with a 4% bunp in the workout. I suspect that with newer trainers this would be less of a problem.
That doesn’t make sense….if you bump up the intensity on the trainer, the intensity at the pedals goes up as well.
Seems more like a falsely calibrated Trainer to me.
Also, Pedals don’t have a train-drive loss, so it should normally be single digits higher readings.
I replaced the internal spacer on the trainer last week. They seem to last 4000-4500 miles. This made a huge difference in the resistance. I did a kickr spin down two days before the ride. I agree that the pedals wouldn’t have exactly the same output but having to bump kickr to 215W to match the workout pedal output of 195W seemed a bit steep. It’s really not that big a deal for me to have both apps up and power match.
Again, that is not how it works. If you are increasing the resistance on the trainer, the resistance at the pedals also increases.
O usualy launch Z road I wanna use for TR workout and during that ride I launch the WO. When its done I also usually stay for a couple extra minutes. It all goes to TR in an unique activity. But not sure those extra “warmup” and “cool down” minutes are reflected on the AI analyse of the WO. ![]()
Does the KICKR Climb respond to gradient changes in Zwift if doing the TR workout through the Zwift integration?
Thanks for the quick reply
Can anyone explain why I am seeing a different recommended workout in TrainNow on my phone vs the recommended workout in Zwift? Gave up trying to figure out why and just did the one in Zwift but I was all set to do the workout shown on my phone.
If you’re talking about the Train Now workout in the TR app on your phone vs. what’s in Zwift, I think the issue is that you need to pick which of the three Train Now workouts you want to do, and then add it to your calendar, and then it will be pushed to Zwift. TR only pushes workouts that are on the calendar to Zwift, and the Train Now workouts aren’t actually on your calendar until you add them.
Thanks mate that fixed it
I came here for the exact issues last asked above by Nigel and found my answer. Thank you!
I had this same workout suggested on Thursday and glad i read before i used Zwift. I did the workout in TR and did get AI FTP Detection afterwards.
For now it seems any workouts PL >9 if you want AI FTP you should use TR. I wonder if there are any other differences?
But it surely would be nice to get the tilt while working out.
Question about the integration - today I did a workout in the TR app while also riding an event in Zwift. After the TR workout, I was prompted for an FTP change due to a hard workout (high PL). I declined by accident, it was the first time seeing this and I thought I could make it suggest it manually again.
It got me thinking, if I only do my workouts on Zwift will I see these prompts in the future somehow? And now that I’ve gotten one today, will I see another one if I do an endurance workout tomorrow?
Apologies if this question has been asked before. I’m enjoying the TR/Zwift integration, but I’d prefer the workout graph to show on Strava rather than the current useless Zwift route map. Is this possible? I only use Zwift for the visuals to take my mind away from the workout. I’ve tried using replays of Bob & Phil at this year’s TDF, but they just bore me to death.
Or even better (for some), the Zwift visuals AND the TrainerRoad graph? Is it possible via the API to send extra media?
