Zwift & Trainer road integration issue
Hello there, nearly each week I have to go to the TR “connections” page and remove the zwift connection and re-add it, as it didnt push any workouts into Zwift (even though the icon appears on the TR calendar with the Zwift Z in the top corner of that workout). Is anyone else experiencing this issue?
Have not had this issue ever. My TR workout is always in Zwift, and always shows in the ‘For You’ carousel.
Is it possible you just don’t have a workout scheduled for the day your checking in Zwift?
Interesting, I do have a workout scheduled, but also it typically when working properly will show you the workout thats coming up the next day as well… in the “for you” area I would get nothing, and if I dive into the workouts section I cannot locate it there either. Once I disconnect zwift on the TR website, and reenable, and then restart zwift it loads everything up and the workouts show in the “for you” area as well as in the workout section.
Happened again last night - I am wondering if its an issue that I usually run Zwift on an iPad, but I am also logged into zwift on my phone to check upgrade status or set a bike up ahead of time in the garage for an event (even though i kill the app on the phone when i am done using it) and thats causing some issue with the integration?
Being logged in to Zwift on two different devices is definitely a recipe for trouble. You say you are ‘killing’ the app, but are you sure? If you’re just putting it in the background then you’re technically still logged in. You should be purposefully exiting Zwift after each use on a tablet or phone, and then force-quitting the app, also. And definitely don’t log in on a second device while actively using the first one.
Yeah, I do quit / kill the app and not just toss it into the background on the phone, and never sign in on my phone while I’m actively logged in on my iPad. I also kill the app on my iPad each time I am done riding in Zwift. I will check the iPad when I get home to see if its pulling in the TR workouts, and then I will not sign in on my phone at all for a few days and see if the integration continues working on the iPad.
@Mwil, it might be worth doing one more dis/reconnect from TR to Zwift.
But this time, try logging out both TR and Zwift on all devices, both on the app and on the web, clearing your cookies/cache, and then logging back into both TR and Zwift before reconnecting the two.
I’ve seen issues with wires getting crossed if there is other login information stored somewhere on your device when syncing two platforms…
Had to reconnect the integration again last night before riding as when I launched Zwift on the iPad it didnt pull in the TR workouts. I’ll try nuking all the logins and caches.
Ok, so I hadnt signed in to Zwift on any other devices except the iPad, and when I did this, the workouts were present in Zwift on my iPad that i typically do my workouts with. Going to test “signing in” on my phone and see if that breaks the iPad’s connection again.
What did you find? :eyes:
Don’t know if I can just jump in. I have the exact same issue, but now for the past 2 days no matter what I do the workout does not get pushed to zwift from trainer road. Anymore trouble shooting options?
Once I stopped signing into the game on other devices it’s been fine, but the moment I sign in on my phone or computer to the actual Zwift game (not the website) it interrupts the connection somehow. I’ve had to disable the connection on the TR website, quit Zwift on all devices, like force it to be closed, then reenable it on the TR website and then wait a few minutes before launching the game again, then it’s always appeared - sometimes it’s not in the “for you” at the top, sometimes you gotta go into workouts and it shows up there…
Are you using an iOS device?
There is a bug with Zwift’s latest update that’s being discussed here.
We’ve confirmed that there is a known issue with Zwift version 1.92 that causes TrainerRoad workouts to not sync correctly on iOS and Apple TV. Zwift is aware of the issue and is working on it.
We don’t have a timeline for the fix just yet, but we’re in contact with Zwift’s engineering team, and we’ll share any updates as we get them.
Temporary workaround:
There’s a temporary workaround you can try in the meantime.
  • Open the TrainerRoad app and drag your workout to a different day on your calendar, then drag it back to today.
  • This can trigger Zwift to recognize and load the workout again.
  • You may need to repeat this process multiple times. If the app is restarted, the workout may disappear again.
yup, using an iPad, after I sent this I saw the thread, I’ll try the work arounds. Any idea why my wife is not having the issues, she is also on zwift version 1.92 as well and uses and iPad.
thanks for the prompt reply.
Mike
I’m honestly not sure, but it does seem like this isn’t affecting everyone for some strange reason.
Regardless, Zwift says that a fix is on the way.
Thanks for your patience! :handshake:
