Wall mount tv/monitor stand that angles up?
I want my TV low, like 2 feet off the ground, but angled up as it’s so close (just 8-10 inches in front of my front wheel). All the tv/monitor mounts I have seen or already have, do not tilt up enough. They maybe can tilt up at 5 degrees, but I’d like more like 20 degrees or more.
Anyone know of an affordable mount? Current TV is a cheap 32", and I have a nicer 4k 27" monitor I might go back to. Ultimately I’d like the ability to hold something as big as around a 42" if I find one cheap enough.
Thanks,
I bought this for an LG computer monitor I use just in front of the bike.
You can see it in this post:
The double screen looks cool.
My low tech version is just to lean the telly up against the wall.
Thanks, that’s an interesting option. If possible, I’d prefer wall mounted, just to keep the floor clearer.
Right now the tv is sitting on top of a stool, and likely would fall if leaned back.
I just realized my work wall mount monitor mounts tilt enough. They were around $50 from Home Depot. I might order another one of them. That would also give me the advantage of being able to put the monitor back against the wall in a vertical position when not in use.
Will wait just in case someone has a better option though.
Thanks,.
I always wanted to try installing one of these to the wall for the lower tv for a cleaner look, might be a good (but not cheap) option for what you are trying to do
