Thoughts on intervals.icu data breakdown
This bug has been fixed. Tx for the report.
Hi @davidtinker First of all, great tool. Thank you very much for making it and continuing to improve it!
I looked a few places and I didn’t see a way to chart left vs right power balance. It would be good for checking how you might have muscle imbalance and how that changes based on fatigue, cadence, power output etc. Just having that as a chart to stack with the others on the activity page would be fine, then I can visually make those comparisons.
Personally when I glance at my left / right balance during a ride I will see 45 or 46% left sometimes (and stay there for a while) and other times it is closer to 49% left (again staying there for minutes). A chart like to show L/R % would go a long way to figuring out why it varies.
Tx. Unfortunately the Strava API doesn’t give out L&R power balance so I can’t show that in Intervals.icu. I have a todo list item to allow manual upload of ride files, sync with Garmin Connect etc. to sort that out.
I think there is a slight bug in the power chart. When you add another/older season to be displayed, it will have a new colour. But when you delete the last 42 days graph, the line colours in the graph and legend run out of sync. The legend gets updated with the top season in green, but the lines in the graph stay the same colour they were before.
Tx for the report. That bug should be fixed now.
The fitness page on my profile is coming up empty:
However the other pages like Activities and Power contain current and up to date data?
I already tried to refresh the page and restart my PC.
Anybody know what the problem could be?
Please msg me a link to one of your activities on Intervals.icu and I will have a look. It is probably a bug that I can fix.
I wonder if there is a little bug in this graph and table shown in the screenshot below.
I’ve done 2 activities in my “this season” and the “last season” ended on 1st June, yet the same power value shows up at the 5min mark of the table and graph despite this being a PR set on 2nd June (and so shouldn’t affect “last season”)
The graphs legend also shows that the “last season” value is taken form the 2nd June despite just below that, it defines “last season” as 4th May to 1st June.
Really love intervals.icu, such an impressive toolkit that you have put together for us all. Many thanks.
David – How can I set a rowing FTP for my ergo sessions? Right now it’s calculating load off of power, and a 160w row for an hour is not at all like a 160w cycle.
I get a bit of a bug (looks like just the chart, the data for the intervals is correct) when I click “Use Laps”. The laps on the chart dont align with the actual lap timings, see img below (should be pretty obvious where the laps actually started/ended)
Please send me a link to that activity so I can have a look. Often Strava sends back bad lap data if you have the privacy circle enabled so it could be that but I need to check.
Please send me a link to one of those. Do you do also have HR data for rowing?
David –
Did it calculate load off off power, or off of HR? If the number is off of HR, ok.
The load has been calculated from the HR data. That is why there is now activity power page for that activity. There is a power trace but Strava has "device_watts": false so Intervals.icu displays it but doesn’t use it for anything.
Would this mean you’d also get the lap data out of the device? If so that would be huge for us who do TR outdoor workouts or outdoor workouts in general. To not have to manually correct the intervals in the activity would be really sweet!
Yes it would solve that issue as well.
@davidtinker I’m trying to add an estimated TSS (load) to a ride I did yesterday without a power meter. When I update it and save it reflects correctly on my charts and in the activity. However, a couple of minutes later the estimated value is removed.
Am I missing something about how to add estimated TSS to a ride done without power?
No it shouldn’t have disappeared. Could you please send me a link to the activity. I can look in the logs and try figure out what happened. Tx.
@davidtinker, Just feature request / suggestion:
Would it be possible or practical to include the labels and scales on the left AND right side of the Fitness chart? It’s a bit of scanning, especially on larger displays, to see where some data points or lines align with the data values on the scale.
For sure can do that (for big screens, not needed on small ones). Good idea, it’s now on the list.
