So Iām not lifting to failure.
And I do weighted squats every session.
Should I avoid this feature, for now?
As an aside, I would personally love for TR to implement strength training plans. There is so much information (good and bad) out there, and it would be amazing to have cycling specific strength training, that aligns with you current training plan phase.
Have you guys played around with adding a RPE or a soreness rating to the working sets? I imagine that may be much tougher to model, but it would make this feature much more intuitive for users.
I would chime in as another one who disagrees that exercises should go to failure.
There are also ways to estimate 1RM without actually getting to failure, and then using that like an FTP to do a 1RM% for your workouts - there are calculators out there based on the amount of weight and number of reps done. This is what I do in the winter months - I do a 1RM estimation workout test, and then use that as a base to set my weights for subsequent months, adding weight as I progress. Something like this would be safer. Going to 1RM for anything is dangerous, particularly for many of us who lift without spotters.
I also agree that squats are important but need to be taught/learned properly. Form is soooo important, not just for squats but for a lot of strength training movements.
I also disagree with his hot take of saying no one should do squats. Beginners should know theyāre beginners and if they get injured itās more likely from trying to squat too much weight. Sure poor form can also be a cause but itās 2024 thereās millions of videos for free how to do a squat.
Squatting down to the ground or āass to grassā should be a natural movement, imo. Humans have done this for thousands of years, up until recently. Where sitting in an office chair for 8-10 hours a day is now ānormalā. Causing lowered crossed syndrome and many other flaws in their mobility.
Also going to failure on sets of any body part is a recipe for injury or overtraining. Maybe a better way to explain it would be lift until your form starts to break down.
As I said, if you leave 1-2 reps in reserve thatās probably fine too.
Squatting to failure is hard to do safely. I recommend using a hack squat or pendulum squat (if you have access) if youāre going to attempt this.
In general I think either of those machines are better for most athlete (but not all) compared to barbell squats.
I can talk about all of this more in depth in the next podcast. It will be a couple weeks until itās out.
If youāre doing like 50% of your 1RM for 4-5 reps, then yah, I donāt think you should use this feature.
If youāre really pushing hard and going close to failure, then yes, use it.
I think sometimes we think weāre pushing ourselves but we really arenāt; especially in leg movements. Just recently I thought I was going to 1 rep in reserve on leg press. I found out I could do 10 more
It hurt so bad but when I took myself to true failure I could go a LOT further.
Barbell squats are hard to take to true failure safely, so you might never know where your limit is because you rack pretty early. All the more reason to use a machine like a hack squat.
JoeX, if youāre not doing very safe exercises that you can take to failure or 1-2 RIR (dumbbell curl, lat pulldown, tricep extensions, machine press, etc) then you are definitely leaving gains on the table.
Thatās tough because soreness doesnāt line up directly with fatigue or muscular gains.
RPE is also hard for the reason I stated above.
I might not be explaining what lifting to failure means, because it doesnāt directly relate to your 1RM.
Iām not talking about maxing.
Iām saying that you do bicep curls until you canāt do any more bicep curls. Aiming for 5-12 reps. Then bonus points if you do stretched partials but thatās probably beyond the scope here.
IE if you think you can do 3x10 @ 70lbs for bicep curl, and the first set you can only do 9. Youāve gone to failure on that first set.
For squats, I donāt think you should go to failure for the reasons Iāve stated in other posts. You can go to 1-2 RIR (reps in reserve) and get the same benefit. If you leave more RIR than that, you are leaving a lot of gains on the table. There are many studies that show this.
As someone said above, thereās a meta analysis that shows that going to failure has an exponential increase in gains compared to leaving a few RIR. I donāt think everyone agrees with that meta analysis but itās largely been accepted by the lifting community (take that for what it is).
What I have seen is that your lifting sessions have to be intense. You canāt do 3x10 when you could actually do 3x25 and expect significant gains. Thatās what weāre getting at for having failure or near failure (1-2 RIR).
As far as the squats vs not; thatās a different discussion and maybe we should have a different thread on it.
Squats have been the bread and butter for decades. Recently they have gone out of style from body builders to NFL players because of their higher risk of injury and the amount of neuromuscular fatigue vs how much strength/size you get from them.
If you want to do squats and you like them, do them. If you hate squats, donāt feel bad about it. Two great alternatives are hack squat and pendulum squat.
If thereās more confusion about the reason why lifting needs to be intense, or what RiR are let me know and Iāll create a video for this forum thread.
I didnāt say no one should be doing squats. And Unfortunately, beginners arenāt the only ones who injure themselves doing squats and videos arenāt super effective for getting people to squat with good form.
I think there are superior exercises that offer same or better size/strength while having a reduced risk of injury, neuromuscular fatigue, and require less skill.
But by all means if you like to squat and can do it safley, do them.
Thanks Nate, not sure if Iām going into a strength focus or not. Bike was my focus Q1 and Q2, now itās running. Thinking of going into a strength focus mid Nov for two months, then two months swim focus, then back to bike
Look forward to the podcast, looks like youāve already got a lot of material to cover but would be good to hear you all touch on phasing for multisport athletes.
@Nate_Pearson until
you bake strength into the training plans, will there be an updated blog post or something to talk about what a pre-base strength block might look like, what kind of bike workouts to do during such a block, and how to maintain that strength throughout the season? If I understand you correctly the ālift to failure and donāt squatā doesnāt really jibe with the old blogposts which werenāt much help on periodization of strength training anyway.
I would enjoy this thread.
https://www.instagram.com/tv/CerZpTvlfFY/?igsh=c2ZiNHk0MzhtMXdq
Saquon Barkley is only on of the best running backs in the NFL currently. He doesnāt seem to be afraid of squatting.
I would also like to see some post on whatās recommended for training phases and how much strength todo during each. NFL and cycling are 2 different sports obviously, unless youāre an Olympic sprinter on the track.
Thatās a good idea, Iām talking to the team about it now.
It worked for me, or googleā Saquon Barkley squattingā
Youāll need to schedule strength sessions individually right now. Weāre working on adding a repeat option.
Are those strength sessions manually entered in Strava? Weāll import only if the activity was recorded with a device.
You can record directly in the Strava app or manually add your session in TR by clicking on a day in the web calendar (soon in-app), selecting āStrength Trainingā, then adding the working sets data.
Thanks for this explanation - that makes total sense. Youāre right, thereās a difference between 1RM and lifting to failure. But I have a question - if you get to the point where you lose form, is that failure, from your definition?
It s a bit crazy but Iāve been thinking about this. The focus strength and HIIT gets for the aging I might swap endurance for 400m track as I turn 50! Its mostly lifting and short runsā¦
