Stem with internal cable routing & steer tube brake hose access
Curious if anyone has been through the same dilemma and found any alternatives.
I’m looking for stems (120 or 130mm) that feature internal cable routing and have a top cap system that allow for a brake hose to enter the stem through the steer tube. The only two options i’ve found are the FSA non-Series ACR Stem and the (too short) profile designs tri stem.
I’ve looked through the offerings from FSA, Deda, Enve, Ritchey, Zipp, and Speacialized.
My FELT AR frame has the following cable routing currently. I’ve designed a custom stem spacer that would solve for the red hose(currently rear entry) to the front, however the green hose is the issue now.
TIA
I know they say it’s only designed for Allied frames but I know the Allied Echo stem routes cables through the steerer?
I’ll have a look. Thank you
