I am seeking a solid, budget-friendly set of aluminum clinchers to replace my Alex ALX-200s, which are stock on my Fuji Roubaix 1.0.
These wheels would be used primarily for outdoor riding/training in South Florida, ergo, very flat terrain. It may be useful to note that my groupset is 10 speed (Shimano 105 5700).
Any recommendations and personal favorites are appreciated! Thanks.
Depends on how rough roads are, your weight, and if you like truing your own wheels. I’m pretty light but still went more more spoke count because peace of mind
I’m pretty light (148 lbs) and I would not be truing my own wheels. So, I a presume lower spoke count, for (minuscule) weight savings and lack of tension adjustment on spokes, would be ideal for me. Is that right?
I’ve been very happy with the alloy Hunt wheels. ~$450, tubeless and tubed compatible, ~1600 grams. Comes with all sorts of adapters So will work with whatever axle standard you have. I’ve raced about 12 cyclocross races on them in addition to a couple thousand road miles and they havent needed trueing at all.
Hunt Aero Wide , Cero , American Classic , Fulcrum Racing 3, Campagnolo Zonda or something along those lines should be fine. Heard good things on the wiggle Prime wheels but their hubs suffer in the wet a lot.
The more spokes you have the easier it is to true a wheel if a spoke brakes or becomes loose. Also the wheel may be a bit more rigid with more spokes. If in doubt go for more ^^
For budget clinchers, keep it simple and just get a solid wheel with a hub you can service. If you are in the USA, Colorado Cyclist builds a ton of wheels and offers very good pricing on their pre-specified handbuilt sets.
For example, DT411 rims on Shimano 105 hubs, 32H with the spring sale code are $300 Choosing Mavic rims can get you under $300
If you get hung up on spoke count, which I wouldn’t worry about, then upgrade to DT350 hubs and the set is $500 DT350 hubs are rock solid.
The small builders are going to likely be using a Novatec or Joytech hub. Nothing wrong with those, but I’d rather have a DT or Shimano hub for the same or less money.
Another DT 350 hub fan here, not for anything other than the total lack of faff. It is sometimes cheapest to buy DT factory wheelsets than buying the hubs and building custom.
I ran a set for 4 years without any maintenance. The freehub started to make a noise so whipped it off, one pawl was sticky so greased it up and was fine for another year.
Then one of the rear bearings was a little noisy so I swapped out all the bearings (a half hour home job with some sockets, few blocks of wood, a drift and a hammer) and good as new again. Total cost was maybe £30.
Have never had to have them trued, they are still virtually straight and very round.
Originally the wheels were £400ish RRP, weigh 1500g and will work tubeless. Not deep, not fancy, just solid.
When built up a new bike last year I bought the modern equivalent which is slightly deeper and slightly wider. £200 in OEM spec (so only QR, not other end caps), 1550g.
Mavic Kyseriums. I have a set I’ve used for years. Bombproof, you can service the hubs, and light.
Regardless of what you buy, look at the used market. A ton of people are swapping to disc, or new racing wheels, etc. You can pick up a killer set of wheels for cheap (used). I’ve bought all my sets used and never once had an issue.
My 1600 are actually to replace a pair of worn out mavic kyrium elites.
I can’t really fault the mavics for reliability and performance but the reason I’ve not gone for mavic again for my winter wheels is that I really struggled to source spare parts.
I snapped a spoke and no local bike shops had them, even the nearest official mavic dealer had to order them in. Then the spoke retaining clip fell of the rear hub and I can’t get hold of that at all.
I was also put off that there is no rim wear indicator on my mavic rims - I’m replacing mine now as they are definitely concave but would have been nice to know if they are still safe.
One thing that is annoying with the otherwise excellent fulcrum wheels is that only the disc brake versions are tubeless ready - I would have gone for the racing 3 if this was not the case.
