Progression Levels and Failed / Incomplete rides
Unicorn -4 by grcycle at Sunday, Sep 19 2021 - TrainerRoad
Chicoma by grcycle at Wednesday, Sep 15 2021 - TrainerRoad
These were workouts I had manually added. I did not successfully complete these rides but have the progression rating boost (+2.7 and +1 respectively) all the same. I did respond intensity too high on unicorn-4.
That seems counter intuitive. Is that right ?
I have since restored the calendar back to TR approved unedited structure. Is the the boosted threshold progression rating a concern ? I figure that AT and a correct survey response should sort that out.
GR
Best call is to check in with the team at support@trainerroad.com so they can look into the breadth of your progressions and the ‘success’ or ‘failure’ of that workout to see what resulted in that change. Cheers!
Thanks, the issue was sorted out by Evan/ Support
GR
What was the issue? Always interesting to understand :slight_smile:
I understand that it was a known issue with some workouts which even if not completed fully / successfully upped Progression Levels and that the issue was fixed. my undeserved level boost was also set right
GR
Just got the same problem. I failed a workout after 2/6 repeats and just rode easily after that but I still got a progression level increase even though I marked it “did not pass”.
Hey there!
I just ran a refresh on your Progression Levels and it looks like that did the trick to accurately reflect the feedback you gave Adaptive Training via your post-workout survey.
Let me know if you run into any other trouble!
