I started having spinout issues while using TR on my Wahoo Kickr Bike Shift. What happens is, when I’m in an non-cooldown interval (say with >150W target), and if I try to maintain a cadence of >80RPM I’m forced into a spinout to be able to track the target power.
Let’s use the example of 202W target interval, which is a level I am able to maintain for extended periods. As soon as the interval starts, I hit just above target, say 205-210 range and settle at 80-85RPM expecting the ERG mode control loop to hover things right around 202 as long as I maintain a stable cadence. What happens instead is, the trainer lowers resistance, and power reading starts slipping slightly below target, say 198 and then 195. If I maintain my cadence it settles quite a bit below target (say 5% lower). The only way to hit target power at this point is to increase cadence, which turns into a death spiral. In a 2 minute interval I’m forced to reach 100-110RPM if I really want to remain at or above target. It’s really affecting the quality of my workouts.
This effect isn’t as bad at lower RPMs, say 70-75 range (which isn’t optimal to be stuck at for training). Also this effect seems to have started relatively recently. I was able to track much better a few weeks ago. I did a FW update on the trainer very recently, but I’m not 100% sure whether this problem started with it or not.
setup:
- latest TR app on iOS.
- Kickr Bike Shift on v1.21.18 Firmware
- TR app set to use Kikcr in ERG mode
- ERG power smoothing enabled through Wahoo app
I will also try on the Wahoo app itself with a manually set target, but I wanted check if the community has any ideas.
