When my trainer road workouts get pushed to my Garmin the power ranges specified get grouped.
And I’ve read about why this can happen during warmups and other efforts so I’m not coming in blind. But today’s workout structure made this less than ideal.
the workout was Teapot, and the two core sets were 10min long and structured as follows in TR.
so it made sense and I mentally prepared for the ascending over/unders outlined:
255w for 45s followed by 315w for 15s (2x)
270w for 45s followed by 315w for 15s (2x)
285w for 45s followed by 330w for 15s (2x)
300w for 45s followed by 345w for 15s (2x)
315w for 45s followed by 360w for 15s (2x)
But when it got pushed to my Garmin it only showed this for each of the over/under intervals:
255-315w for 45s
315-360w for 15s
It’s one thing if it’s a long temp interval of like 30-60min and it says 220-240w.
But for vo2 max over/unders I really need to know the exact targets for each 45s and 15s or I’ll push too hard early or too little later.
the whole interval segment was setup to be ascending and once I saw that’s how it looked on my Garmin I memorized it. But I’ll admit half way through both sets I forgot where I was.
any help on how to change this would be appreciated. Thanks.
I am struggling with the same type of issue. When doing a workout outside on my Garmin, I get a range of, say 215 -230 and my actual target is 220. Nowhere on the screen does it tell you the actual target. If I’m supposed to do, say, 3 x 10 min at 220 but I’m doing 230, I could easily cook myself. I try to memorize it, but some workouts have so many different targets that you can easily lose track.
This is overthinking it. In your example you’re given a 7% range. Rather than believing that 220 is the exact specific magic number that will make your workout perfect, you should understand the range and target working within it, using your own feelings and other input to meter the effort. Your own individual zones will vary by 5%+ on any given day and even throughout a workout. When you’re given a general range like that, just target the middle of the range and adjust accordingly as you feel it out, don’t make it more complicated than you need to.
The vo2 workout for the OP is a different story because I think that workout is specifically supposed to be an increasing effort, so just laying out the ranges does seem like a bit of a miss..
When you switch it to ‘outdoor workout’ I also have come to find out from Support that many are vague alternate workout targets. Makes sense - but weird at the same time for many of them like Teapot , that clearly has varied targets. But I guess suppose if you looked at workout… you just know stay near bottom of ranges… then move to middle… then upper end by the finish.
I did a long zone2 with many 8-15min (or something) fluctuating targets with sections of 55% and some up to 75%… then after warmup when I got into it… it was just ONE 3 HOUR interval with a huge range. lol was like… well… guess i’m just doing whatever for 3hrs
