I’m not quite sure how this happened but I have ramp tests in my plan for two weeks in a row. This is my first cycle through a TR plan and I’m coming off a build block. These rides starting Feb 1 are the beginning of my rest week. Should I hit AI detection on them both as they come up, or should I do that on one and delete & replace the other with a regular workout? Does it matter?
Maybe you set up a plan then adjusted it. That can cause multiple ramp tests. Doesn’t really matter what you did, the moment you go use AIFTPD its swaps the ramp for a work out. There was a refresh bug when AIFTPD was still valid for the 2nd ramp but hopefully thats sorted and it’ll automatically swap the ramp again. If not contact support and they’ll sort it out.
