Ah that makes a lot more sense. And agreed, definitely tough but very possible with a correct ftp.
You’re not alone. I read that as 64 minutes straight too.
Rosillo is correct.
Just to clear things up, accepting an FTP Adjustment should not have any effect on your current 28-day timer linked to AI FTP Detection.
If you run into an experience where that’s not the case in the futre, please let us know! ![]()
I had the same thing, I turned it off in settings it was very annoying
Maybe TR has recently fixed this problem, but having my next detection bumped out four weeks is exactly what happened to me. Here’s my exchange with support from December:
Kent M. (TrainerRoad)
Dec 8, 2024, 11:51 PM PST
Hi there, Patrick,
Kent here, thanks for reaching out to TrainerRoad Support and for being such a long-time fan of TrainerRoad and AI FTP Detection!
It looks like you recently viewed your FTP value 11 days ago, which automatically resets the 28-day window for AI FTP Detection. This is why your next detection date was pushed out. AI FTP Detection is designed to allow athletes to view their FTP on a rolling 28-day schedule to ensure adequate data for accurate calculations.
However, I completely understand the situation and have gone ahead and reset your AI FTP Detection date.
Let me know if you have any other questions, and I’m here to help as needed. Keep up the great work!
Kent M.
Customer Support Expert
Patrick Hill
Dec 8, 2024, 5:59 PM PST
Hello. I am a long time TR subscriber and big fan of the AI FTP detection feature. I recently completed a level 9.0+ sweet spot workout and was prompted to detect my FTP. I said ok, but later learned that the system wasn’t really detecting my FTP, only arbitrarily suggesting a 2% increase. It looks like since I asked it to detect my FTP (which I don’t think it did), it shifted my next detection date four weeks further out. Can you please reset my FTP detection date so that I can check it through the model tomorrow (12/9/24), which is 4 weeks from my last real FTP detection. Thanks!
I believe what you’re referencing from back in December of 2024 was an FTP Detection, not a 2% FTP Adjustment.
Those 2% FTP Adjustments typically only happen when you’re in a Specialty phase to help ensure that your FTP doesn’t jump up too high, resulting in a significant reduction in PLs, which isn’t what you want when sharpening up for your A race.
Since you were in a Base phase at that time, you received an actual AI FTP Detection, not an adjustment, which is why your AI FTP timer was reset.
Early FTP Detections can be prompted after passing a level 9+ workout when you’re outside of a Specialty phase (again, the 2% FTP Adjustments only happen in Specialty phases).
Does that make sense? All of this is outlined in the Help Center article below if that helps.
This or do the whole workout at a higher intensity. Even a 5% boost makes a difference.
