I have mild knee discomfort presently, basically, my right knee feels like it wants to pop, then after a few miles, it does. When climbing the stairs, my right knee clicks a bit. It doesn’t hurt, but it is a bit unsettling. My right hip also clicks when squatting whereas my left does not, sometimes it seems as if after my 2nd set of squats, it stops even if I go as deep.
I recently (about a month ago), moved my saddle back 1cm and prior to that raised it up about 4mm. The reasoning for that was a few things - I felt like I have been swinging my right knee out when pedaling and originally had my saddle about 2cm higher before seeing a fitter. When my saddle was up 2cm from where it is today, my left leg used to swing out. I still have sit bone discomfort which is part of the reason I hop around in the saddle, the other is that when I am sitting where I think I should, my body feels awkward, like it doesn’t want to be there. My body tends to favor one side. I feel like I tend to experience saddle discomfort for the first 45 minutes of the ride and after that, perhaps my body relaxes and I tend to hop around less.
I have focused on spinning rather than grinding through too hard of a gear and routine stretching after every ride longer than 30 minutes or with a higher intensity.
I do basic strength training off the bike using body weight focusing on the arms and legs with some core:
pushups / bent over row / dips / plank / side plank / russian twist / superman
lunges / split squat / wall sit / ball roll out / bridge / V-up
I also do some mobility exercises to improve mobility in the toes, ankles, knees and hips:
reverse lunges / bear crawl / walk on toes with toes pointed in / monster walk / hip hinge / step down
The mobility exercises were originally for my knee pain when climbing the stairs (my motivator for seeing a PT 6 months ago) and big toe arthritis.
That said, I’ve come across this:
and, that post seems to lead me back to PT. I’ve stopped seeing my PT as it is a huge time commitment (at least 1hr there, plus 30m commute round trip) and I can do most of the exercises at home.
So, it seems from the link above that there are likely other muscles that are tight that I’m not stretching as well as building the proper coordination or strength.
In summary, I will incorporate those PT exercises into my routine, but I appreciate any other feedback regarding bike setup or PT. How often do you incorporate PT into your wellness plan and once it gets better, do you ease out of it or do you continue as preventative medicine?
Thanks,
