Thank you ![]()
Keep up the great education work here!
Is there an advantage to tailoring the overload to the specificity of an event? E.g. long threshold vs VO2 for 100mi gravel events where TTE is more important?
won’t speak for the Dr. but if your TTE is already good, you might want to do vo2 in prep for a gravel event anyway in order to raise your ftp ceiling and then commence work on TTE. it depends on what you need and when
Here’s something I posted to the wattage list in 1999, after I had been using a PowerTap for a year:
Top 10 things I’ve learned using a power meter:
- I shouldn’t lose weight
- I need big gears
- I need small gears
- Strength is irrelevant
- Don’t start too hard in TTs
- Train less, rest more
- Heat acclimatization is critical
- Specificity
- SPECIFICITY
- SPECIFICITY!
Another way of answering the question:
What are the demands of the event?
What are the characteristics of the athlete with respect to the demands of the event?
How do you best prepare this athlete for this event? (Or: should they choose a different event, thus exiting the loop?)
Return to step 1.
Could you elaborate?
Any companies/individuals that you see privately working to improve?
A world class performance of 500w only requires 48Nm of torque at 100rpm, that equivalent to a 29kg weight pushing on the end of a 170mm crank.
If a 70kg rider applies their bodyweight on a 170mm crank, throughout the pedal stroke at 100rpm it
works out at 1215W!
We’re already strong enough, unless you’re training sprints.
Even sprinters are strong enough - it’s more power they desire.
Joke sort of loses its punch when the forum software automatically renumbers your list…
Xert XSS seems to improve on it a bit.
Thought you had added items (since the last time you posted it) and were holding out on us. ![]()
and even then, my basic understanding is that you want more PCr stored in muscles + high glycolytic capacity. I’m not a physiologist so someone please correct me. Said in simple terms, its one reason why track sprinters have such large legs.
I’ve been using Athlytic app on iOS, and a year+ ago played around a bit with FasCat Optimize. Optimize goes a step beyond Xert IIUC, in that it attempts to factor in some recovery metrics. Athlytic does as well, without using/adjusting TSS.
- I need big gears
- Son’t start too hard in TTs
- Specificity
- SPECIFICITY
- SPECIFICITY
Dunno…seems to work OK. ![]()
David Letterman would not approve.
Not that I am aware, but no reason for me to be either.
Thinking on the anecdote trying the Hickson protocol, althoug it is impossible to impact isolated one specific “area”, within type 3, can we do any distinction between ones that are more focused improving VO2max vs improving fractional utilization over a given time?
This leads me to another question: which are/is the more important physiological factors that limit the fractional utilization? Thanks in advance.
Yes, you can almost certainly bias things toward improving cardiovascular vs. muscular metabolic fitness to some degree by manipulating your training. The thing is, there is considerable overlap, and you need both, so at the end of the day, it’s all good.
Far and away the most important factor is mitochondrial respiratory capacity.
ETA: Re. point #1: once upon a time, I reasoned that since I could maintain ~90% of VO2max for >1 h, I should focus on raising my “ceiling”. 18 wk of 3 d/wk Hickson intervals later, I hit my highest VO2max ever (5.45 L/min at 67.5-68 kg). I then raced the Texas state TT, and got my butt kicked.
Moral of the story? Train for performance, and let your physiology sort itself out. In particular, don’t underestimate the importance of specificity (specificity, specificity, specificity, specificity…is there an echo in here?).
True! But for a 40k TT or a crit race, it is maybe easier to ‘find’ the specific workouts you want to do to improve your performance. What if you do very long gravel or granfondo events (5-8h events with A LOT of climbing). What do you want to specify their? Endurance? Climbing? And even those climbs could be 60-90min climbs or 5-10min over FTP climbs. What do you focus for those races? Build an aerobic engine and then 8weeks of specific intervals that mimic the hills/mountains in that race?
“find workouts”?
Do you mean, how do you decide what to do?
If so, in no particular order my general recommendations would be 1) just try different things and see what works, 2) find something or somebody trustworthy to help guide you, and/or 3) develop sufficient understanding of exercise physiology principles that you can guide yourself.
What I would definitely not recommend is continually jumping on the next bandwagon that comes along (“Maffetone”…“40/20s”…“sweetspot”…“polarized”…“lactate testing”…“zone 2”…“Norwegian double threshold”…etc.) and/or expecting miracles, as there none.
Yes, that is more correcly what I was trying to say! Thx for the good answer @The_Cog, seems some good advice. My goal is to use some insights I have collected from different sources and guide myself in my own planning. A-event is still 6 months away.
I also have some plans already from the past in my trainingpeaks. Even a base/build (Epic Build your base/foundation 20 weeks) by Hunter Allen, but never used it. Still in doubt to start this one, although it seems good, maybe to much intensity. And by ‘self’ coaching it is maybe easier to develop a weekly schedule based on time available then follow a rigid plan.
First 4-6 weeks is base build. Use Z2 rides (low, mid, or Lt1) depending on time available). And then incorporate after a few weeks some tempo work, later on sweetspot.
Goal is also to do every 8-10 days a more intensive rides (structured, or zwift race). I will use WKO5 to track my TSS, Tis, TTE on when to decide when to go to a more intensive aerobic block to start working on FTP work. Or even before a 3 week vo2max block…
