Yes! BIg fan of LS jerseys. And I go so far as to wear LS lightweight SPF jerseys (favorites are from Boure) in conditions as I like them better than slathering on sunscreen. (Necessary too as my dermatologist has already cut out more than a few abnormal sections of skin – fortunately none malignant.)
I seem to have developed an allergy over the last couple of years to certain sunscreens. I can use the spray mineral lotion or mineral lotion in a bottle, but if its not mineral based, I will itch for days.
Mineral sunscreen is like glue, getting that shit off post ride is brutal, might as well plan on it being on for a day or two, and it leaves me looking pasty white/half dead zombie.
Got a summer long sleeve jersey from Pactimo that I tried at a gravel race this last weekend that was fine, also picked up some sun sleeves to try this year. Trying to minimize the sunscreen on my arms. which seems to be the most sensitive.
It’s pretty rare. Almost as rare as me going for a long ride… ![]()
Though it’s becoming more common and will become more common.
People forget how far north the UK is, the northern border of California is at only 42 degrees latitude, the southernmost point in the UK is at just under 50 degrees which is further north than Vancouver! I’m at 56.8 North in Scotland, We might get a UV index of 7 around midday on a uncloudy day
around the summer solstice
Me cycling outdoors? I hope so.
Actually climate change is more likely to shift us back into Dickensian weather, with a frozen Thames in winter and everyone being paid in candlesticks they can huddle around for warmth. Mini ice age.
So…fat bikes I guess ![]()
Well it’s already shifted us into these floods over winter with the wettest February on record etc and rainfall 3 times the historic average of last 20 years.
Getting mineral sunscreen off my hairy legs is a PITA
. I haven’t found good summer leg screens, though. I use ones from Bontrager and they slip down my thighs.
Has anyone tried Ornot long sleeve jerseys for the summer? That’s next on my list. I usually use MAAP evade pro or Rapha pro team training long sleeve jerseys.
Yes, I have all three or those. The Ornot (not the merino jersey) is nice but a little thicker than the MAAP or Rapha. By the time it’s hot enough to notice the difference, it doesn’t matter. It’s just hot at that point.
The MAAP jersey has an odd fabric, almost plastic feeling, but I like it a lot. The Rapha Pro is nice and feels more airy than the others but again, it’s not that big of a difference.
I just got the Ornot Lightweight Long Sleeve Park and really like it. Mineral sunscreen becomes a mess on my arms when I sweat so I’m switching to long sleeve in warmer weather. It’s early in the season so I haven’t ridden it in temps over 75. I overheat easily so if it’s going to go above 85 I don’t go out and ride inside with the fan on high.
Embrace the heat - if it’s dry heat!
I ride in the San Gabriel Mtns. In Southern CA. It’s certainly a dry heat!
I grew up in the Central Valley. Still never got used to the heat! Part of why I like cyclocross, it happens in the cooler months.
I’m part polar bear, from the midwest. Trust me, riding in the heat is worth it. Just ride easy and the gains will come.
I’d like to see a study on how different colors affect core body temp, not surface temp.
I think if surface temp rises, core temp will rise too. But that’s just an assumption.
It’s literally how we cook things.
Definitely not rocket science that darker fabrics make you hotter - you can feel it in the sun on a hot day. I have a Voler lightweight long sleeve in a very light gray that I’m really liking. And, have spent a lot of time looking for light colored jerseys.
But, I think the color / heat thing isn’t in all cases. Take the Bedouin robe article above, basically it creates airflow, so heat buildup from a darker color doesn’t matter in that specific case. I think this could be the case with darker colored helmets when there’s airflow. I’m still in the white camp though because there are those scenarios you find yourself cranking slow up a hill in the beating sun…
I do have merino, but it doesn’t dry as easily as synthetic, so evaporative cooling isn’t as good. Definitely amazing in colder weather because it’ll keep you warm when wet (although synthetic insulations do that too - but you need the loft) and it also resists funk a lot better than synthetic.
