πŸŽ‰πŸŽ‰πŸŽ‰ Introducing AI FTP Detection πŸŽ‰πŸŽ‰πŸŽ‰
Looking into this now!
After seeing chads post above I went back and looked at my calendar. I am using a standard plan and yesterday was scheduled the ramp test at the beginning of sweet spot base 2. I accepted the new ftp (a small increase). My ramp test was replaced with a vo2 max workout with a level of 5.1. My bo2 max progression level went from 4.9 (where a 5.1 would probably be productive) to 3.9 (where the 5.1 workout is a stretch) after the ftp update. In the past I have closed the app and upon reopening it have seen ramp test replacement workouts get adapted back to a productive workout for the new ftp/pl. so in my experience it seems like the replacement gets added based on the old PL and then only gets adapted for the new ftp/PL when the app (iOS) is closed and reopened.
Looking to add some extra β€˜volume’ to my low volume traditional base plan I am doing over the winter (in week 2 of Trad Base I currently) and would like to choose the option that will have the most impact on my AI FTP. Which of the following options would help boost my AI FTP calculation?
A) choosing a higher PL workout as an alternate once or twice per week (Klammspitze instead of Fletcher, 20 more TSS, extra 30 mins, 0.1 lower IF, 0.4 higher PL)
B) adding an extra lower level endurance workout once per week (For example Carter 34 TSS, 45mins)
C) adding an extra lower level threshold workout once per week (For example Sanford -1 50 TSS, 45 mins)
Is the answer based on boosting your TSS the most or your PL, I expect both are factors but at the start of this plan AI FTP suggested a drop (I rejected it) put in a ticket and they couldn’t tell me why a drop was suggested but have continued on and haven’t had an issue.
If someone like Ivy looks into things related to that, I also had an issue last week where I did my Sunday workout (Gibraltar -3) on Saturday and it disappeared from Sunday on the App but stayed on the Sunday on the web calendar.
Awesome, Chad! Thanks so much for following up about this, I’m hardly surprised that one was manageable, you’re slaying. :sunglasses:
Nonetheless, still brought this to the team for improvement of the Experimental POL Plans. Many thanks, you rule.
There’s a timegate on every plan that prevents being assigned the same workout in too close of succession. It doesn’t yield the best result for both motivation, and in your fitness progression to be doing the same workout the following week, in Chad’s example. :+1:
Thanks for bringing this to our attention!
If either app is open when the replacement workout is scheduled, it gets locked with the Ramp Test and results in an error. We’ve reported this to the team and will work on a fix!
A suggestion to prevent this in the short term is to make sure not to leave the TrainerRoad apps open for extended periods of time between uses. Issues like this are typically more common behavior with mobile devices rather than desktop, but that should help in the meantime while we work on that fix.
Cheers!
