🎉🎉🎉 Introducing AI FTP Detection 🎉🎉🎉
Is the 14d thing still a thing?
Yes, AFAIK it is.
Nate mentioned they have every intention to set and keep some limits on it moving forward. So it may change the specifics, but there will be some form of cap from what I have heard.
I hope they can add a 6 hr buffer or something.
I woke up this morning wanting to update the estimate and give the app time to update my PL’s before the workout. This doesn’t seem to happen right away for me.
It wasn’t 14 x 24 hrs since the last update though, so I did a workout and updated after.
Tried searching but didn’t see an answer. If I use FTP detection but don’t accept the new FTP, do I still have to wait 2 weeks to use it again?
@ambermalika
@IvyAudrain
no, you don’t. You only have to wait two weeks after actually doing an FTP change (no matter how that change happened, whether manual or ramp or AIFTP or whatever).
So yes, you can peek at it without committing.
Cool, thanks. It’s mostly curiosity. I just finished a 3 week block and was curious how FTP detection would give me an FTP before and after a recovery week. Not planning on accepting the pre-recovery FTP but didn’t want to mess up the post recovery week FTP estimation.
How would I do that?
I have my first ramp test scheduled for tomorrow morning, and like many here, I’m still in trust-but-verify mode.
You get an option to accept or reject the estimate, just reject if you want to do the ramp test anyway
My value was slightly lower after my recovery week (248 vs 246 up from 242)
But the library is set up best for having the correct estimate in your ftp. While there are a lot of workouts to choose from, there aren’t a lot that have the same interval length and rest interval and only differ by percent of ftp target. (At least notc that I’m noticing) Really the only way i can do that is to manipulate the intensity level.
Does the AI FTP feature require maximal efforts? Does it take into account outside rides, or only TR activities?
Read the first post in this thread :wink:
I’ve had my PL being nerfed to 1.x after a few watts FTP increase too.
Twice.
I ignore the PL nerfing now. I wish there was a feature for it ( you accepted this higher FTP, do you want to reset PL too?) but it’s easy to just take a screenshot of your PL and just select alternates at what the PL were before the FTP bump. So far, i haven’t hit a wall. That may change once i reach PL 6+ .
I think it’s simply that the AT and the AI FTP detection feature don’t cover well the case of someone coming back from off season. I took 2 months off after ironman Arizona and both the ramptest ( i don’t test well generally) and the AI FTP detect underestimated my FTP. After 2 weeks of too easy workouts, I did the good ole 8min test and now the workouts feel right (with PL uppers 3.x ) i.e. somewhat challenging but doable.
i only ever got one FTP detection value. I closed the window instead of accepting/rejecting and never saw another “detected value” since. I got the “Hang tight” message whenever i retried.
Support said a week ago to update manually which I did.
In a week, I’ll see if this feature works or if i get “hang tight” again.
So impressed with TrainerRoad’s new AI FTP detection. The lowest of all the AI estimates (322w @ 4.66w/kg vs. 336w [intervals.icu], 352w [Strava], 339w [Xert]), but the one that I actually believe and feel able to train to…
I am doing the ramp today, I used AI last time and was bumped to 320, out of interest I used it again today without accepting the result and its given me another 1.9% to 326; interestingly this is 75% of the last minute of todays scheduled ramp test… so to achieve the AI FTP I would need to ‘complete’ the entire ramp test?
Has anyone gotten an endurance workout after using AI FTP detection?? I just got Townsend after using it just now. 2.6% increase, 272>279. I was expecting a sweet spot workout, especially coming off the recovery week.
The ramp test will just continue to add steps until you can’t turn the pedals anymore. After that, when it realizes you are done, it will switch to the cooldown part.
I suspect the reason it is shown the way it is when you look at it beforehand is that the break even point for your current FTP is 19:30 minutes and it is shown going for 20 minutes, which means many people will stop somewhere in that step.
The fact that your estimated FTP corresponds to exactly 20 minutes of a ramp test at your current FTP (I haven’t checked your math here) is just a coincident.
The last minute on the ramp is 435W, 75% of that is 326.25, my current FTP that is set is an AI FTP of 320 from 2 weeks ago, I suppose as you say if 19:30 is break even @ 320, then 20:00 would mean the ramp would agree with the new AI FTP of 326W.
Sounds like someone needs to start their 21 minute of the ramp test now. Just to prove AI FTP wrong.
So, ramp test result is in, 299W… 6.6% decrease, considering AI was trying to bump me to 326W this has left me with little trust in the system :-1:
