What is your VO2 progression level?
I just ran ftp detection and got a 3.7 percent increase which I am totally happy with. My compliance to scheduled workouts is great now and I am challenged but not crushed. I am even planning to buy power meter pedals so that I can record my outdoor rides in the summer and do two TR workouts per week indoors as well so that the AI will have enough data to keep me training year round (except for a 3 week time off the bike rest.
But this brings up my question:
- is anyone doing something similar and are the outdoor rides being used by the AI to make adjustments to your plans and ftp appropriately?
The reason I ask this is that last week (during my recovery week) I did the Sufferfest tour de sufferlandria where power data was of course recorded onto strava and then ported onto my TR calendar. However it does not seem to have had any impact on adaptions being made to my plan or progression numbers.
Does this mean that outdoor numbers are taken into account by Adaptive training but training on other platforms is not? Inquiring minds that want Zwift and TR to merge want to know.
5.2, but I’ve been doing custom workouts so take that with a grain of salt
This is a 2 part question/answer:
AT Training Plans: AT will adjust Progression Levels based upon actual TR workouts performed inside and/or outside. It is not officially supporting “unstructured rides” that aren’t those former versions. However, some people have been applying hacks to try and associate their “unstructured rides” with TR workouts. I just don’t know the details or success of that. TR is actively working on “Levels 2.0” that is aimed at handling ALL workouts for AT & PL use.
FTP Detection: TR is using any and all ride & workout data that includes power, as well as heart rate apparently.
The changes you saw jive with some of my hunches.
One last Q: what was the progression change and rate roughly of your VO2?
I started at 1.0 with the progression originally because I hadn’t done vo2 work in months, but I was doing roughly the same workouts, 4x4, 5x4, 4x5, so not really doing a progression in the sense of AT
Got it, so does that mean you jumped from a 1 to ~5 pretty quick and have stayed there pretty much this entire shift in focus?
I suspect the FTPD baselines off a current FTP input and then basically increases/decreases to keep progressions going. That could lead to changes in the recommended FTP that are inconsistent with how one is feeling about their current fitness. But there should be a floor on how low it will go, based on raw performance.
Note that I am not suggesting the model is designed to do this or not.
Anyways, thanks for sharing. This is a useful non-standard use case that helps provide insights and will help users down the road.
Yesss!!! Thank you! I read it to mean go to Career page on the desktop version and I couldn’t find anything there either.
Much appreciated!
Mike
I don’t know if this was one of the intended use cases, but AI FTP Detection was a carrot for me today.
TR said, “Your FTP is X,” and I said, “I’m gonna do that ramp test and prove you wrong.” That incentive kept me pedaling when I wanted to stop (or felt like one more pedal stroke would kill me, but didn’t, and neither did the next 30 or so). The live FTP number helped late in the test prompting me to hang on for just a few more seconds to get the extra watts.
For me, the combination worked. I was about 1.5% above the estimate, which isn’t much, but I would’ve been happy with 0.5%, so gravy. Based on other metrics after the fact (HR and time at HR, cadence, how I felt when I could think again and notice how I felt), I don’t think I left much, if anything, untapped.
So not using it as advertised, but it still works. ![]()
Has anyone figured out a solution for the “Processing Data” prompt that doesn’t resolve? I’ve tried waiting 2-3 hours, deleted and re-added ramp test, and deleted my last FTP entry. No dice ![]()
Just used AI FTP for the first time as scheduled (obviously I have been sneaking a look…), 281 from 276 which I would have said was about right… Except I just tested positive for COVID ![]()
Probably need to push out my workouts and reassess. Super mild at the moment but I thought my easy ride last night (Baxter -2) was harder than it should have been and I had a bit of a tickle on my throat when I went to bed.
Not sure what that means for my FTP though as I assume it would be negatively affected by being ill (any illness).
The ftp estimation actually turned out to be within 2 watts of 90% of my 24min TT effort. Surprisingly, very close!
I had very minor symptoms from covid last month. Took 3 weeks to build back the stamina to ride again though, just felt so tired. I didn’t want to push it knowing that can actually exacerbate symptoms long term.
The AI went 217->221->218. I think it’s correct, will know more after a few rides. Going to start over with SSB1.
My n=1 comparing AI estimate to the Ramp Test. AI said 284. I was like “hold my beer.”
Turned myself inside out on the ramp test to achieve a result of… 284. Very precise in my case. Seriously impressive.
Chad ur the best!! Even better than the other chad
LOL, always glad to help when I can. But I am nowhere near what Coach Chad has contributed in the TR universe ![]()
I don’t know if there is a formal solution, but I’ve gotten that prompt a couple of times while using TR on my desktop. Instead of waiting, I actually quit the program and re-log in, and it has then worked for me. Again, I don’t want to imply that’s the “fix”, just something that has worked for me that you may want to try instead of waiting so long.
