🎉 🎉 🎉 Introducing Adaptive Training! 🎉 🎉 🎉
Something is definitely broken. In PC desktop app survey appears and I submit the response, but outcome in website still shows Missing response. On Android app however I don’t even get to submit a response as survey doesn’t appear. When I tap “back” after the workout, app ends up with an empty screen with a spinner in the middle. Have to then kill it using recent apps screen or exit via home button.
Thank you for this paper. For someone outside the field, it is interesting and revealing reading. The question is whether training is more like chess, which machines are good at, or charades, which they are not good at.
One obvious conclusion to me is that we should not expect AT to exhibit “common sense”. In TR world, I suppose that means that AT might draw conclusions from our data that are unrealistic. One example might be progression levels that are too extreme.
Another is that developers and users need to be on the lookout for adaptations that reflect simple correlations rather than rely on an understanding of causes. In training, the possibilities for this mistake are endless, and already something that typifies our field. For example: do TiZs reflect an attempt to be polarised or do they reflect the fact that after a HIT session people need a few days easy riding?
No doubt others among you can think of more profound conclusions.
AT going a bit crazy with my VO2max was one of the reasons I stopped using it. It wanted me to do a 5.0 today though my level is supposedly 5.9 (was 6.9 as recently as two weeks ago).
I did a 5.8 as a compromise and to be honest it probably wasn’t as hard as it should have been (I don’t think my HR made it into VO2max levels). One bright side is that it now isn’t offering me any VO2max adaptations (it’s still insistent on dropping my sweet spot though).
Edit - I should note that I kept the types of interval the same. It was pretty consistent on wanting to drop all of it.
Those are pretty different VO2 workout profiles though. One is short shorts and the other is more traditional intervals. From what I can tell, AT maintains an understanding of how you perform in each of the subcategories of each zone and serves you workouts that fit your abilities with respect to that information. I’ve noticed this with my own VO2Max prescriptions from AT over the past several weeks. My VO2Max level is actually lower for the longer intervals and higher for the short shorts, which I also know from experience aligns with ability to succeed in those workouts. I’m certainly better at one more than the other, so to see AT actually recognizing and adapting for that is quite cool for me (and it’s been bang on).
All that is to say that I don’t think what you are sharing will be uncommon for those using AT. It happens with a couple of the zones, but most notably happens with VO2Max and Threshold workouts (both have 12 subsets when you filter by them in the workout catalogue) as there are several ways to elicit the training adaptation for them.
That Tuesday swap looks like a case where the progression level might be too high for Ansel Adams / too low for Baird. Maybe AT is smarter than the progression values and is giving you a harder one :slight_smile:
Baird is a much tougher duty cycle (60/30 vs. 50/40 is a big difference), and shorter rests between sets. The only thing you can say for Ansel Adams is 135 vs. 120% target, but I think I’d still find it easier with the much more generous rests.
I disagree with the assessment that Baird is harder. Ansel Adams is more intense across the board by all metrics, despite the increase in rest time. It’s IF is still .91 with that increased rest. It even has less endurance time at the end because the rest between sets is longer too. That makes those sets just that much harder.
Never mind - tonights ramp test increased FTP a measly 2%, and VO2 progression went from 5.4 to 2.3, so I guess another round of adaptations is on the way…
Just did Ansel Adams and :cold_sweat:
Something like that. Here’s what support told me (and probably @trpnhntr):
We did issue some fixes on the AT end (which, this display issue was a part of) yesterday, so moving forward, we shouldn’t run across this specific progression display being incorrect bug :slight_smile:
Did you report this to support@trainerroad.com? The survey prompts very inconsistently for me on Android 9, and support has been working on it. If it doesn’t prompt, you can press the ... button in the bottom left and choose Update survey response to fill it out.
maybe it assumes success will come on Tuesday? Anywho - have fun trying to stand up from the toilet Thursday night!
I performed an outside workout last night. It included a pause of the workout/ride, for a nature break and to let people regroup. As mentioned in another post above, I got a “struggle” survey, which I find quite annoying.
The break was roughly 3 minutes, and the only applicable option in that survey is “Other”. I added a note about why that gap exists, along with my displeasure in the designation by AT.
  • Perfectly fine. Only stopped for a brief nature break and to regroup with the other riders. This is not and should NOT be a fail.
Gotta say that the detection on this should be better than what I see here. Comments were made by TR that breaks like this should not lead to “struggle” surveys, but I am not seeing that here. Maybe the threshold on duration is too short for practical cases.
I get that 3 minutes break in the middle of a long SS or Thresh level workout could be a sign of a problem. But 3 minutes in the middle of a long Endurance interval? I think there is insufficient “smarts” or consideration here.
Maybe the early parts of the ride where I exceeded the targeted power (while rolling in the group and in a firm headwind), also lead to the altered designation? But if anything, I would think that being over target would trip the “Super Pass” option and not the “Struggle” one.
Apologize if this is a stupid question or if it’s been asked before BUT - How will I know when I get into the beta for adaptive training? Did you get an email? Does Beta just update and let you know you’re in?
You get an email
Too polite! Next time be more clinical (stopped to urinate) and maybe that will trigger AI to stop asking :wink:
Having not dealt with AT affecting my training plan (since I’m not following a TR plan), this is my biggest pet peave with AT. Such huge (sometimes seemingly completely random) changes in progression levels with small changes in FTP.
Yup, I am not excited about my next FTP test because of this. I have still not seen any comment on the massive reductions showing up from these other than the acknowledgement that they are looking into it.
If it’s a bug, it would be nice to know it, and that they are looking to fix it.
If it’s intended behavior, I’d like to understand why, because it sure is not obvious to me.
On the survey response saving issue:
  • After some work with the TR support team, it appears that this could be tied to it taking time for the TR app to save the survey response - separate from saving the workout - to the TR back-end
  • So if you are having issues, try leaving the TR app open for a while after completing a workout - don’t quit the app immediately after completing the workout and completing the survey.
I saw this manifested for me as: I quit TR as I normally did after completing the survey. When I checked on the web, the survey was showing as missing. I then re-launched the TR and, and the app showed the survey response. I caught a screenshot showing this. Right after I captured the screen shot, I saw the survey response show-up in the web browser. Luckily I caught the screen shot showing the TR App / web browser discrepancy before the web / TR back-end was updated.
There really should be a way to override the struggle survey (both for indoors and out). I’ve had to go to the door for shopping because they’d turned up early, and I’m sure people have had to stop their kids / pets from getting up to all sorts of mischief etc etc.
“No, it wasn’t a struggle. It was…”
“1 - 5”
2-3% off a ramp test would be a big change for me, and I’d for sure struggle or fail threshold and above workouts if they stayed at the same progression level. 2-3% is often the difference between making and failing very hard workouts.
