NB this question isn’t about whether you could connect a running power meter to a trainerroad widget and perform a workout, it is more about whether the parameters of the workouts/plans are suitable for running training.
I am considering purchasing a stryd for running. Could this be used effectively with trainerroad plans? (For example, doing SSB1 entirely with running). I understand the running FTP and cycling FTP are different, but assuming you adjusted it before starting the workout, would the % of other levels still correspond across zones?
What other factors are there to consider? Would cycling workouts normally be too long for running? Would you see performance improvements in the same way?
