Feeling frisky and Ai delivered a new ftp that I feel is to low. How do I bump it up to where I want it?
Another option would be to ride Aleutian, Lewis Lope, Prospectors, or something similar.
Sure, if you want to wait 4 weeks to fix the issue.
Would doing a test work? I thought doing a test would set my FTP to the test result.
TR AI FTP is not the same as TR Pre-AI FTP
I assume that means that you would get a different result from a test? Be good to understand that…
So I manually changed my ftp and did my first workout with it ( over under) and it felt perfect in a challenging kind of way. It keeps asking me to use Ai ftp detection to set me at the lower number and will not project my ftp four weeks from now which is disturbing but I hope it will sort itself out after a few more workouts!!
You will have to wait until your next detection for it to sort itself out, but at least you now have a good value for your training.
I’m pretty sure it does not. I’ve ramped, I’ve rolled an all out 20 min, ftp hasn’t changed. But sometimes I get mad and want to show it who’s boss.
So if you do a ftp test and the result is different from the current AI FTP, TR doesn’t adjust the zones for subsequent workouts based on the result?
I haven’t been on TR since last Jan but before then I remember it did.
I just looked back, I did the trek 1,000 mile challenge in July, almost all at low intensity (about 50% ftp) and wanted to see how I was at the end so did a 20 minute effort at 326 watts on July 30 (my best 20 minute power since June 2016 so that was an awesome surprise) and my next aiftp number was 290 on August 10th which was a 2 watt increase over the July 6th aiftp of 288. Back in May, AI said it was 297 and I did 325 watts for 20 minutes on April 8.
So if you have an infrequent monster ride, I don’t think it moves up your training zones or ftp that high. And I’m glad about it, 5-10 watts higher and I wouldn’t be making it thru my hard days, they feel plenty hard as is. (I’m 87kg fwiw)
OK. Was that 20 minute effort an actual TR test? I guess I’m asking if TR responds to the results of its own tests. As I recall, it did adjust zones on the subsequent workouts after a test.
If you do a 20 min test, is FTP still 95% of that?
It depends
and there is added confusion with how tr defines their own version of ftp
Ah yeah that could be it, it was “just a ride”, not a TR workout/test/ramp.
To ask the question a little bit differently, if I did a 20 minute test two years ago and another one again today at same watts, should I enter the same FTP into TR today as two years for workout purposes?
Asking @eddie here on this one…
Did you use 95% of your average power to find your FTP two years ago? That’s what I’d start with for a 20-minute test if I did one today.
No I always did ramp tests.
Is my formula wrong?
Your response is a bit cryptic. Are you saying enter any number that you like cause it doesn’t matter?
My question is - how do I determine the ‘right’ ftp number for TR AI plan creation?
Our first recommendation is AI FTP Detection. Are you having issues with that?
Ramp Tests are okay. 20-minute tests are a bit harder to get right, but you can build the skills to do them well.
Why are you doing a 20-minute test? What did you do to calculate your FTP after taking one two years ago?
I guess my response was trying to say that 95% of AP for a well-paced 20-minute test can work well for an FTP, but sometimes it’s a bit high, and sometimes they are difficult to pace properly.
Let me know if this helps or if I’m missing something here.
