How many people are regularly doing Progression Level 10 workouts?
Seriously, who does these? What kind of athlete are you if you do - are you pro? Is your FTP by any chance too low?
I am regularly browsing the vast library of TrainerRoad workouts, planning what I will attempt for the following week or two. Currently I am somewhere between PL range of 4 to 7 in SS, TH, VO2.
Every once in a while I take a peek at the PL 10 workouts and just think to myself that there is no chance in hell that I could ever complete such workouts. They look totally batsh*t insane. I can take an educated guess that it’s for the folks whose FTP isn’t going up for some reason and they’ve simply worked their way up to that level. But holy crap, this must be a super low percentage of the population accomplishing such a thing.
Not entirely sure which workouts you’re singling out as batshit insane, but towards the end of a 3-week phase, it’s not that uncommon for me to be assigned 9.5-10.5s.
And no, I’m not a pro. Mid volume home gamer, <3w/kg.
If you read the descriptions, they do in fact say successful completion is perhaps an indication that your FTP has improved.
Are you saying if you were to update your FTP, start a 3 week build block and starting from a say, level 3 threshold… You will be hitting level 9 by the end of the three week block?
Depends on zone and your power phenotype.
Example, I am experimenting with reverse periodization (intense winter, long distance summer):
  • during typical summer training (4xZ2 + 2xSS/Z4) I’ll become time triallist and I am literally unable to go below PL9.5 for Sweetspot – FTP increases slowly and whenever PL drops immediately after detection, with next workout it is again above 10 and adaptive training can’t guide me
  • during winter with more VO2max/anaerobic centric training, I’ll become puncheur and yet highest VO2max PL is around 8-9 and more typically in 5-7 ballpark.
For context, I am average cyclist. Maybe strong at steady low-intense efforts but still average.
I’d say it depends on how accurate your FTP is and your current FTP relative to what you consider your peak fitness.
I top out in the 290-300 range and might hit those numbers if really good consistency over a long period of time with no sickness.
In my experience I have only hit 8 - 10 range in endurance, tempo SS when I was working off 250 - 260 and plenty of scope for improvement. Threshold I’ve never really got close to 10.
So a newbie or person who has lost fitness and rebuilding stands a better chance of topping out the PL.
A lot of the higher PL workouts are just long.
So yes, doing like 5-6x20-30min @ SS is something I do a number of times a year in my training. And a 6h endurance or 3-5h long tempo ride could even be a weekly thing.
My FTP is not set too low. I ride 12+ hours a week when I’m training. I am not a professional rider.
Remember that FTP is the power you can hold for ~40-70min. Doing something like 3x25min@94% of that value should be a difficult but doable workout based on that, as long as you are doing enough volume that the fatigue from the length of the workout alone isnt causing the problem.
Exactly, not batshit crazy, and perfectly doable if your FTP is in the right place.
I suppose one can cherry-pick some PL 10 workouts that don’t look so bad, and can be accomplished by not so exceptional cyclists, like me. E.g. Wright Peak 3x30 SS looks somewhat doable as a near/mid-term goal.
But then I see Redondo +4 which is an hour long, and that just looks insane to me and unrealistic.
I guess TrainerRoad hasn’t shared data on this - or have they? - but I would expect there’s a bell curve situation going on where people will mostly fall into a PL 4-7 range.
Anyone want to share a pic of their calendar full of 9’s and 10’s?
It probably depends on the plan, and on the power zone. I’m on a half-distance high-volume triathlon plan, and my hard workouts on Tuesdays were sweet spot for the base phase, VO2 max for the build phase, and threshold for the specialty phase, so I never got to a very high PL on any of those because by the time I got to 5 or so, I moved on to the next phase. But every phase had weekly tempo workouts, so it didn’t take too long to get to PL 10 on those. Accepting an FTP increase doesn’t knock down the PLs all that much, just enough to make the PL 10 workout “productive” again instead of “achievable”. I’ve done Polar Bear like six weeks in a row at this point.
I haven’t done many other plans, but if another plan had, for example, sweet spot workouts in every phase, then I imagine it wouldn’t be impossible to hit PL 10 naturally in that zone.
Ha! I looked this one up to check it. I looked at this and thought it was pretty straightforwards. Certainly a hard workout, but should be doable.
It’s just 50min@94%, with a brief break every ten minutes, and some sprints thrown in. I actually thought it looked kind of fun.
Again though, if you’re using something for your FTP other than the power your can hold for 40-70min or so, this would probably kill you :winking_face_with_tongue:
This is from 2nd block of Masters General Base. 1st block took to Sweetspot PL10 and in this block, AT become useless because it does not go above 10 :slight_smile:
5x10m under ftp with 2x30s accelerations is not an insane workout imo. It’s a hard workout but if one has an accurate FTP and has done some work at extending their TTE a bit it’s very achievable.
Impressive! Nice work!! You guys are giving me inspiration…
I’m with you. At the very end of my noob-gains period I knocked off Three Fools -1 at L9.2 (I joked that it had been done by two-fools-minus-one… very hard but doable without bailouts), but then six weeks later I was brought to my knees by Caldwell at L5.6. :confounded: Obviously the ability to actually get any recovery in a 15-second valley is a special kind of superpower, & for me at least the workouts that use them have their PLs underrated. TR dropped my sweetspot level by about 3 points because of that failure, but later that week I got some retribution by dropping in Antelope +2 & easily passing it. :person_shrugging:
I want to thank everyone who contributed on this thread. It gave me enough inspiration and motivation to pursue my first ever PL 10 completion. This also happened with a recent FTP bump, where AI suggested +4 and I just rounded it up to 275 (4.3 w/kg). This workout is quite an achievement for me and I’m feeling pretty proud of myself at the moment, lol.
I cherry-picked Paradise which is a 2-hour hard-start upper-end of sweet spot workout. I had been working on VO2 for a while now, getting that up to PL 7.0 just the other day; that definitely helped in dealing with the hard-starts. And yeah, after the hard starts it felt like it took 2-3 minutes to get back to normal sweet spot RPE.
This is the activity. Hopefully this link works.
https://www.trainerroad.com/app/activities/356747707
What’s next? Well I still think a lot of the PL10+ workouts are pretty insane, but maybe not so batsh*t insane as I originally thought. Today’s was a ‘very hard’, I guess my goal for sweet spot will be to do more PL10 workouts but get that down to just ‘hard’. I’m not sure I can get the other systems up to a 10 but I’ll give it a try.
Thanks all!
Hi again!
For anyone who has done it, do you have any thoughts on Baird Peak SS PL 10.3?
I just did it today and it felt relatively easy for the PL. Not actually easy, and I conservatively marked it as ‘hard’ instead of ‘moderate’, but it seemed way more doable than Paradise which I did a few weeks ago.
If you’re in the SS 9’s and 10’s, what is your favorite go-to workout?
I can’t speak for the SS workouts specifically, but I think sprints throw off the model that calculates the workout levels. The Boarstone workouts are a good example I’ve seen, Boarstone +1 is a tempo 10.7 even though it has less TSS and lower IF than Boarstone 9.5, but it has sprints:
Both workouts you mention have sprints, but they may still explain why the one with higher WL felt easier, maybe it’s just that the sprints are artificially bumping the WL.
Interesting! Thanks for showing the Boarstone comparison.
It’s a bit strange as the 10 second sprints on Baird Peak felt like part of the warmup, and were so short that they were basically a non-factor to the workout. Whereas on Paradise the 30 second hard starts immediately into SS were definitely a major factor to the feel of the workout.
I kind of thought that the TR staff manually set the PL levels for each workout, but a slightly buggy algorithm might explain things.
I could be wrong about that! I just have the vague memory of someone in TR’s staff mentioning it’s algos-generated. Also, there’s ~5,300 workouts, so maybe I just hope they’re not doing that manually :sweat_smile:
Marcus Baker series and Pendleton because these workouts have consistent 20min intervals at intensities 88-94%, giving you good indication when it is time to check for FTP increases.
