How it started, how it's going aka predictions vs reality
:sweat_smile: I just saw a full schedule. Didn’t realize Mondays was cropped off.
Carry on….
@Bones I think you posted this across a number of different threads, and I think I addressed it somewhere. :thinking:
If I haven’t yet, please point me to the threads where you brought it up so that I can share my responses where it matters most.
Hi @eddie, 10 days ago you asked me: “I’ve got some ideas of what might be going on here. Are you cool with discussing your training here in this thread?”
I responded yes go ahead, but unless I missed it, I don’t believe my questions were addressed.
I also asked this above.
Yeah, it’s likely that your FTP is set too low.
You crushed that Sweet Spot workout yesterday and went over the power targets, which was rated 9.8.
If that felt “hard,” as you said, then you’ll likely need to bump your FTP up to keep some breathing room. I just ran an FTP detection for you and it gave you a higher number. Let me know if you want me to share that here or in private. :zipper_mouth_face: :flexed_biceps:
That big jump we were predicting (~12%) was a much better estimate of where you should be at based on your recent performances, so, although it seemed optimistic, I think it was more a sign of how low your initial detection was.
Why did this happen? It looks you stopped filling in RPE surveys around early April of this year. On top of that 2 of the most previous 34 recorded rides prior to that FTP detection had power data attached (September 20th and 29th). I guess that was enough to give you a low estimate. :man_shrugging:
Let me know if this helps and if you have any other questions about this.
Thanks for your patience on this one! :handshake:
Yeah, I’d like to know what the FTP detection gives me! Go ahead and share here. Thanks!
I am just getting back indoor training again for the winter and having a look at my first block my workouts are set to jump massively in difficulty in that one block.
I started with a ramp test on Monday and then a 2.2 difficulty sweets spot on Tuesday. At present my ftp is predicted to rise by 22 watts in 25 days time. I personally don’t see this happening.
The reasoning for me is that my workouts are set to increase from sweet spot 2.2 difficulty up to 8.2 in the 3 week block before my rest week.
Realistically I will not go from a 2.2 to an 8.2 in that time frame. I imagine as I complete and rate my workouts the workouts will adjust accordingly and by the 3rd week I won’t be attempting an 8.2 difficulty sweets spot as workouts will change and therefore my predicted FTP now will never materialise because of that.
Do you think the number you got from your ramp test is realistic and will give you good training?
If so, keep it. Do the workouts. Rate as appropriate. Don’t worry about 4 weeks.
If not, consider manually increasing your FTP and seeing how that affects the next 4 weeks’ workouts. You can iterate changing your FTP until you’re happy that you’ll be getting 4 weeks of good training.
Yes happy with the test . I only did it as was a bit surprised by the low estimate I was given when I signed back up. Had taken a few weeks off and had just been focusing on running so I’d say that’s what the low estimation was based on but the workouts would have been too easy if I had stuck with the TR estimate.
My main concern was the ramp up in workouts and the AI prediction. I just don’t see me reaching the prediction as I don’t think the workouts currently suggested are attainable in such a short time frame. TR will likely change the workouts along the way meaning I will not reach the FTP prediction.
Is this an obvious flaw in TR’s AI FTP predictions not being a close to accurate prediction?
It seems to be A Thing that the first 4 week period can be a bit weird. After that things will probably (no guarantees!) settle down.
Best bet, I think, is to get in 4 weeks of training that feels productive*, regardless of the predicted outcomes. That’s what you want.
*eg workouts that look like 3 × 15 minutes of sweetspot rather than 6 × 3 minutes of sweetspot or 3 × 45 minutes of sweetspot. If you’ve done intervals before you’ll know what you’re aiming for
300
e7a244ccfe7f6d595a791e7054d0c876
LOL! Is it really 299 and you wanted me to feel better??
Thanks!
If you manually adjust your FTP let me know how your workouts go afterward. :+1:
Thanks Eddie - I did manually adjust it to 300w. I suspect that is a bit high, but I will give it a go. I went through this last winter when accepting (what I think) is a too high FTP. The over/uders were OK at level 3-4, but my z2 felt too high and my SS felt too high. Anyway, I’ll let you know how it goes!
I’m having a similar situation. I’ve had a few months off due to life conflicts (weddings are a lot of work) and got back to things last week. I did a ramp test to give the system some data, which put me at a 40 watt drop from my last FTP detection at the end of June, and then AIFTP came in another 7 watts lower. Now the AI is confidently informing me I can get 35 watts back this month (19% increase) and my sweet spot is already 9.2. I don’t expect it to hold that high an increase through the remaining 3 weeks and those high end workouts are not wrecking me the way they should after so much time off the bike. Gotta love rebound-fitness though!
Yeah, I’d say you definitely need to bump up your FTP. :flushed_face:
I just took a look at what we’d give you today and it’s just a bit under what your next prediction is showing. Let me know if you want that exact number. :1234:
I would love to hear that number! You’re welcome to share it here.
Thanks!
:two: :two: :four:
:eyes: yeah, I guess training at 191 is a lil low, then.
Let me know how things go with that new number in place. :+1:
This behavior of FTPs dropping really far after time off is something that the team is addressing with the work they’re currently doing.
