Help Needed: Any Tool to Correct Power Data when 1 side lost?
My left side power meter battery died almost as soon as I started my ride, so the power data for my ride is ~1/2 of what it should be. Does anyone know of a tool I can use to fix the FIT file and correct the power data?
I used the below in the past with success
https://www.fitfiletools.com/#/top
I don’t see how I can use that to repair the power data. I can strip it out of the file, but what I’d like to do is “fix” the power data. Right now the power data is 1/2 of what it should be - effectively it is only showing the left crank power, and not the right crank.
There is an option to adust the power
Only used this once, but it did the trick for me!
Thanks. That worked. Now, is there anyway to upload the fixed file back into TR?
That’s above my head now.
You could try deleting the original then going to the TR career>past rides and import the corrected file. Garmin Connect does’t recognise the edited file from .fitfiletools for some reason, maybe TR does :thinking:
