Unfortunately, that’s not the official set of guidelines.
Here’s what we recommend using:
Easy
This ride felt easy and non-taxing, requiring little effort or focus. You could repeat the ride and pass it without issue.
Moderate
This ride was somewhat comfortable but required some focus to complete. You felt a little challenged but had confidence that you could finish. If the ride had an additional set of intervals, you could complete it.
Hard
This ride required effort and focus and was challenging to complete. It felt tough, and you looked forward to the ride ending. If there were an additional set of intervals, you could have done it with significant focus.
Very Hard
This ride was very difficult to complete, and it tested you. If there were one more set of intervals, you wouldn’t have been able to complete it.
Maximum Effort
This ride was extremely difficult. It pushed you well beyond your abilities and took a massive amount of energy and focus to complete. You’ll feel like you barely made it to the end of this ride, and that you had to pull out every mental trick in the book to finish. If you had to pause during a workout to catch your breath or adjust the power demand down, the workout was likely a max effort.
- If a workout was a maximum effort because of external factors like illness, poor sleep, or fatigue, be sure to add that detail in the follow-up survey.
Notice that we say “set of intervals,” which means that if you’re doing those really short on/off style workouts such as 30/30s, we’re not asking if you could simply do one more 30-second interval, but rather another set.
In the case where you’re doing longer intervals such as a 5x5 workout, consider if you could do one more interval.
I posted this in another thread which might help explain:
Just to clear things up here, when talking about “sets,” we’re referring to a group of intervals that are tightly spaced with longer rest periods on either side.
Here are some examples of sets:
When we ask you if you could have completed another set of intervals, this is what were asking about. A singular interval wouldn’t really be accurate in this case. The last image is a good representation since each interval is only 30 seconds long. We can pretty much always get through another 30-second interval, but getting through another set is a different question.
There are, of course, examples where you’re not doing sets of intervals, such as with sustained work, and in those cases, it’s best to answer with the overall structure of the workout in mind, with rest periods similar to how we define sets. In these situations, answer if you could have done another interval, as we wouldn’t consider the entire workout a “set” of three intervals.
What we’re essentially looking for is the work done between longer periods of rest.
It’s proven to be tough to get everyone on board with these surveys, and I’m not sure if we’ll ever win everyone over, but this seems to be the best way to describe what we’re looking for at the moment. Using the singular term “interval” seems like it’s less accurate since many or most of our workouts use sets.
Let me know if this helps.
