I have just asked the AI for predicted FTP and increased +12.94% increase, is this right ![]()
The jury is out on this one ![]()
Essentially the algorithm has changed and it is now showing you the optimum FTP for TR to set your optimum workouts.
It is apparently no longer important that it reflects the result you would obtain via an FTP test.
Nate makes a convincing argument to be fair…. it’s all about setting the most productive workouts at the end of the day…. but I don’t like it.
EDIT: after having a bit more of a play around manually inputting different “FTP”s can see the benefit of using the different number and the positive effects on my training. I’m coming round to it ![]()
Ya this one is odd. There is apparently some “good reasoning” behind this but it escapes me.
I can’t especially see the wisdom of essentially saying your FTP is 308 -10 (in other words 308 but we’re lowering your progression levels by 10) rather than just saying your FTP is 298.
But I’m no expert I guess ![]()
It makes rational sense to give the system as many levers to pull as possible to fine tune the workouts, I get that and if TR say that’s what has proven to work best then I have absolutely no reason at all to doubt them.
I just like having the AIFTP be consistent with traditional testing.
It would be interesting to see what would happen if athletes were given the following choices….
A) New AIFTP - This allows the system to give you the best possible workouts, it is the optimum solution to make you a faster cyclist; but the FTP value will not align with past values or with external training programs.
B) Old AIFTP - Can slightly inhibit the systems ability to select correct workouts. Athletes may run into situations where the workouts selected are not as productive as they could be; but your FTP will be consistent with past values and will reflect the value that would be obtained via traditional testing.
Rationally I know I should prefer option A…. but I far prefer option B ![]()
ha. alas we are not rational animals.
this is a great one for spirited games of “Would You Rather” among cyclists! ![]()
Yeah, I guess I didn’t understand what Nate was saying. I thought he was explaining how it had always worked. In any case, you’re right that as much as FTP is valuable as a gauge for training it’s a good metric for comparison. If I understand the counter to that, it would be that your actual PRs should be your comparison measure.
Maybe TR should change the name of that metric. TBP say (Training Baseline Power) just so we don’t have this debate. Also nate mentioned maybe TR could show modelled 20 and 60 minute power. I think that would be good.
I understand then that after the update the FTP IA is not equivalent to the FTP we would have on the street, right?
I don’t understand what Nate was saying either, but seems like there are multiple variables you could adjust. Either AIFTP could give you an “elevated” ftp so that the model selects the best workout for you, OR couldn’t you train the model to do that based on a tested/on the street ftp number?
This concept might work if you only used your FTP to train within TrainerRoad, but many of us use FTP as a metric for other training, outdoors, or even with other software. Not being able to know your FTP as it is measured everywhere else is a backstep that I hope is resolved with an update.
I wonder if they could offer both the old and the new metric and simply rename the new metric to something more applicable.
My entry in this sweepstake is TrainerRoad Power Parameter, TPP! ![]()
Functional Trainerroad Power
Let’s keep the acronym intact for maximum clarity! ![]()
Yeah, the latest AIFTP boosted my FTP by 15 watts, despite me training less. This is pretty clearly too high based on actual full-gas outdoor efforts.
Since this metric is being used to set workouts, I don’t see why it can’t use the actual correct FTP but just serve me harder workouts? Surely the software could be set up to “correct” my FTP upward when selecting my training, but not display an inflated FTP number.
FTP is a slippery beast at best. I think I may start a new thread where we can compare a comparison of our FTP as calculated by various platforms:
For me:
Intervals.icu eFTP 282W
Strava 299W (it estimates it on your power curve)
XERT 291W
TR AI FTP 251W
TR AI FTP v2 not seen it yet
For me:
Intervals.ics: 348W
Strava: 352W
Previous TR AIFTP: 345-355W (slight fluctuation over the year but always in this range)
New TR AIFTP: 365W
Ultimately the number doesn’t really matter, but some consistency across platforms would be nice. TR knowingly inflating FTP numbers as part of their workout selection seems a bit silly.
It doesn’t always inflate it - it’s just different - sometimes the new number is lower.
It’s AI finding the best number to train to - rather than trying to be consistent with anything before.
I’m coming round to it….
Whilst I get where the idea is going and honestly I have found more arguments to remove ftp from most cyclists vocabulary, my concerns come with any other platform.
As a long time TrainingPeaks user this in essence makes the performance manger a bit of a mess. We all know that TSS is not created equal and my ‘diet’ does not relate to yours but have a general grasp on your fitness and fatigue is a good marker.
I guess the only way is to completely remove all numbers and just ‘make line go up’?
I mean in the end faster is faster I get that. I just can’t for the life of me see what’s better about “you’re at the bottom of a staircase that leads to 306” rather than “you’re on stair 298”. And that’s the best way I can interpret this new system. The problem is you can never really know where you are in between. But then again that’s probably within the margin of error anyway (as well as fluctuations in fatigue, sleep, etc) so maybe there’s no point in worrying about it.
ya I got a 16 watt boost this morning - and right before over-unders! - so that’s going to be pleasant.
But I’ve watched more than a few people in the beta thread wonder about this and @Nate_Pearson has been on here going through their rider profiles and it seems like people have been able to complete workouts that they thought they wouldn’t be able to.
So I dunno
if I survive it, I guess I’ll report back! ![]()
I’m coming around to it too.
My last AI FTP with the old model was 279 W, on November 25th. I did a Kolie Moore FTP test yesterday, came back with 271 W, a drop I expected after the holidays. Ran the new AI FTP immediately after, and it gave me 289 W, which seems way off, but after looking at the workouts and reading these threads, I’m coming around to it. Like, my sweet spot workouts are now effectively threshold ones, but maybe that’s the intention: It’s giving me the right watts, regardless of zones.
After reading Nate’s comments on the various threads, I think the ideal future state of TrainerRoad is one where there’s no FTP or PLs or even power zones. The algorithm should tell you “do this workout where you hold X watts for N minutes, don’t worry which zone they’re in” Moreover, the algorithm will game out all the possible scenarios in the simulation window and determine that this particular sequence of workouts is the optimal one that maximizes the results you’re looking to achieve, and you shouldn’t worry if they’re “sweet spot” workouts or “threshold” workouts or whatever.
But we’re not there yet and the system still revolves around FTP and PLs and power zones, so the algorithm determines the right watts for each workout and then backs into the corresponding PL for those and sets the FTP to get the PLs where they need to be. So the system isn’t saying “you can hold 289 W for about an hour,” it’s saying “based on what we know about you, your next workouts should target X watts, and if we call your FTP 289 W, your PLs will be set up correctly to get you there.” In other words, we still have an FTP and PLs and workout categories, but maybe we shouldn’t care about those and just trust the watts.
I’m gonna give it a shot and see what happens. The only downside I see for now is that I’ll have to bring back regular FTP tests so I know how to pace outside efforts, but maybe that’s not such a bad thing.
