So yesterday I did Heseman, a rather unspectacular 2h endurance workout, on one of Zwifts new Paris routes to combine the success of finishing the workout with the success of completing another route.
After the workout was done, I still had about 7k to go, so I answered the survey in Zwift and rode on, keeping my power in the lower end of endurance for the most part.
After finishing it all at a round 75k, I’m now a bit confused: the 5.3 Heseman somehow turned into a 9.2 due to the minor extension. (And the 9.2 also didn’t trigger the FTP recalculation I would have expected when finishing a workout on this PL)
Has anyone else seen such weird increases and could explain what’s going on?
If it’s necessary for support to look at the calendar, feel free to do so and share any insights you find.
I had a look at the workout data in intervals.icu, which should be the same data, and all power zones above Tempo have a max time in zone of 1s, likely from a funky data point due to standing up or something similar. No idea what TR is hallucinating to come up with the increase in Anaerobic
Note: the max watt of 631 (and likely also the time in zones above tempo) was an initial power spike in the first second of the workout - hard first push on the pedal or the trainer messed up the data)
And would I be right to assume this won’t mess up my upcoming detection on Saturday, as the power data looks clean and that’s the main data used there?
it’s been a while on this topic, and I just had a very similar thing happen again: Did a session of Acquaviva, and possibly due to a very spiky first second, what was supposed to be at most a Vo2max 6,3 became a 8,3 with an additional 8,3 on Anaerobic.
Maybe this time around you have the tools and data available to check if the one single spike in the very first second is supposed to have such an effect (and I’m also still curious what happened with the original workout of this topic)
For what it’s worth, the FTP prediction didn’t care much and went down anyway, but that was to be expected as I had to stop a pedal stroke early sometimes
Looks like either your ping or the support ticket I created in the meantime did something. At least for the second workout, the spike at the beginning was manually removed and the levels are ok now.
Same thing, just differently also happened with the first one. Let’s hope the model learns how to deal with those properly eventually.
