Hi
For almost 2 years I have an Elite Suito indoor trainer.
Last year I bought the double sided Garmin Rally power meter and did multiple comparisons between the Suito and Rally pedals.
The Elite Suito doesn’t have a power sensor. The power is calculated based on speed and resistance using a “power map”. (Source: http://52.212.236.181/viewtopic.php?f=33&t=2559)
Last year I contacted Elite support because my power readings were off. They let me follow a procedure and gave me a new power map. The power matched better to the Garmin Rally, but still about 10% off with higher power (while sprinting or Vo2Max intervals). Last year I didn’t really care, because in the range 200W-300W it was pretty good. This winter I’m doing more Zwift racing, so now I do care that my sprinting power is accurate on the Elite Suito ![]()
Below the original power map:
The power map after the procedure with Elite support:
An option is to go back and forth again with Elite support, but I rather understand the power map myself so I can tweak it to perfection.
Does anyone know how to interpret the numbers in the power map?
Thanks!
