Does Ending a Ride Early Affect Future Workouts
I recently listened to the podcast regarding TrianerRoad’s hardest workouts. If this were a manuscript submission and I was reviewer number 2, I’d recommend this for major revisions due to the inclusion of cut short “due to time” or other non-strain related reasons as “trouble.” The fact that you do not trust that self-reported data highlights the fact that it should be excluded. Yes, it is likely that some respondents aren’t being truthful. And it is also likely that some cut the ride short for non-performance related issues. The problem is you have no idea regarding the scale of these. And looking at the data, “cut-short” is a highly variable category by workout. If the assumption is that is really means the rider were struggling, its proportion should either be correlated with the difficulty or at least evenly proportional across all workouts. In fact, some of the easiest workouts have high proportion of “cut short” meaning athletes possibly just got bored. I think this analysis is really interesting especially as Hannah point out its utility as a benchmark to compare yourself to. I would like to see if excluding these “cut short” workouts changes the overall ranking. And FWIW the mistrust of athletes responses is giving off condescending scientist-knows-best vibes.
And to my question, I infrequently but regularly, cut workouts short due to time. I have a narrow window of time to train between work and when I make dinner for my family… guessing I’m not alone here. So if a meeting runs late or I faff about a too much getting kitted up, I may not have quite enough time to finish the prescribed workout. So for longer endurance or sustained tempo rides, I may bump up the intensity a few percent and then simply cut the ride short when I need to be done. Or with many interval sessions there is often a prolonged Z2 before the cool down that I will cut short and drop the cool down. Most often, this is only a few minutes (>10) but according your analysis, this would mean I had trouble with that workout. So, is my practice of cutting rides short due to time being interpreted by the model as me struggling with the workout?
My experience is that it will “punish” you for not getting the right stimulus at the right time. It’s prescribing a certain number of watts, and if you don’t do them, then it will affect your AI FTP prediction going forward. But it’s a different “punishment” than if you fail a workout or mark it as hard.
On Saturday night I was doing a 1:15 threshold session indoors. Twenty minutes in, the power flickered, and my power stopped broadcasting. I ended the workout (and specified equipment issue). Predicted FTP dropped by a bunch of points. Got my equipment to broadcast again, used the AI TrainNow to select a 60-minute endurance ride, completed it with no issues, and my predicted FTP was back to where it was before I rode that day.
That is my understanding as well. If you don’t do the work as prescribed you aren’t getting the training it thinks you need to get to the predicted ftp. This also means you aren’t following the progression set for you, so the following workout has to change.
You didn’t fail in that it won’t assume the workout was too hard but you also didn’t do what it wanted you to do so needs to adjust
I should have been more clear in my question. As both of you point out, yeah I understand that if the volume/intensity what I actually ended up doing wasn’t as prescribed, the model will change my FTP prediction and future workouts accordingly. But if the model take cutting a ride short as a failure due to difficulty, does it then affect the intensity of future workouts? You both seem to think not. Curious what one of the TR reps would say.
Both types of failures will do the same thing though maybe by different amount. Cutting a ride short do to it being too hard means the next ride should be easier as you aren’t at that ability. If its do to time the next ride could still be easier as you didn’t do the work needed to be ready for the harder workout. Both make the next workout easier
In my experience, how you respond to the survey affects how they scale your future workouts. If you say that you cut the ride short due to intensity it will make your future workouts easier than it does if you say you cut your ride short due to illness. You can actually see this for yourself. You’re able to change your response after the fact by clicking on it where it’s written underneath the workout.
So the answer to your question is yes, TrainerRoad does account for how you respond to the survey and reacts accordingly. You don’t even have to take my word for it. You can see it for yourself.
It’s your workout, it’s your fitness, it’s your ftp, it’s your future race. TR gives you the opportunity to be honest with the software, and with yourself. Be responsible for yourself, take responsibility for your successes and errors, deficiencies, self-awareness. It’s not a TR problem if you can’t or don’t do that.
Good tip. Just tried that and holy cow the model is sensitive to that variable. I actually ended a ride early yesterday because I ran short on time. Changing the reason to “intensity” dropped my predicted FTP by 10 watts. But interestingly, when I changed it to equipment issue, it raised the prediction by 3 watts. And illness raised it by 2 watts. This kinda confirms my suspicion that, as Jonathan alluded to in the podcast, the trainer road model doesn’t really “believe” the reason you select.
What are even talking about?!
