CORE body temp sensor
Anyone else order one of these?
They’re shipping once the tour de france is over.
I have one on order, but more from a professional curiousity side…we manufacture medical thermometers so I want to check this out.
I’m a little dubious as to their claims…extrapolating core temp from surface measurements has never been very accurate. We’ll see…
I’m interested in it not just for crazy hot days where my power is garbage and my HR is high, but also on extended climbs where I suffer, I think because at 7mph there is very little airflow. It will be interesting to see the numbers.
Shane how are you validating the accuracy? How you cross referencing against another thermometer?
No sense of adventure. :winking_face_with_tongue::winking_face_with_tongue::winking_face_with_tongue:
Thanks for the feedback…agreed that there is some question about actionable data from this.
yesterday before sleeping i seen this thread, i am very interest in this topic, is it possible to merge with this thread:
So my pre-ordered unit arrived this week. Will be starting to play around with it this weekend.
I remain somewhat skeptical about being able to measure actual “core” body temp via an on-skin unit, but we’ll see.
Also skeptical about whether it has any useful function during an activity…
I’ve used it on three rides so far, and even if there is no actionable data, I consider it an interesting look inside the machine. What I am seeing so far is that it takes a VERY long time for core temp to increase, and also decrease. Yesterday in Chicago it was finally a little warm at 73-75 degrees, but I wore the same exact clothes I wore for a ride at 50 degrees (LS jersey and a noninsulated but thicker vest). Same route, tried to do same intensity, and the core temp max for ride at 50 was 100.4, and at 75 degrees it was 101.1
See two screenshots from Garmin Connect. One is of the ride, and then the other is me just sitting down still for 30 minutes in the same kit outside on my porch having a NA beer while waiting to see how long it took for the core temp to come down. I can’t get Garmin Connect (web) to show in fahrenheit, sorry.
A few things:
Update the firmware using the iOS app. It’s easy in settings, automatically checks.
Put the sensor on a good 10 minutes or so before riding. It takes no time at all to get the skin temp, but core temp takes time to get the first measurement. On my Garmin 1030, it doesn’t wait around long to receive the core temp number before giving up. Turn your Garmin on only after you get a core temp reading in the iOS app. If you don’t you will have to reboot your garmin.
History in the iOS app can be reset, if you get a weird reading (like when you take it off and rinse it) and your Y axis will go nuts making the history tab absolutely useless. To erase the history, swipe the magnetic charger back and forth on the back side of the core (part that touches your skin) and the core will light up green to indicate you’ve erased the history.
Pairing it with a HRM will yield quicker results, according to one of the core team members. You’re probably already doing that.
Don’t bother wearing it overnight for some sort of insight. It’s a really boring result.
Interested to hear what you think when you get a ride in.
Based on the review below, neither of those observations seem correct.
“During muscular exercise, core temperature initially increases rapidly and subsequently increases at a reduced rate”
“During muscular exercise, the magnitude of core temperature elevation is largely independent of the environmental condition”
In particular, it seems that only above about 75-80 degrees F is core temperature elevated compared to cooler conditions.
So no diurnal variation?
I wonder if it could it be used to detect ovulation for those using the rhythm method of birth control?
Kinda doubt it…our basal therms go to the hundredths for additional specificity.
At this point, it appears the CORE uses skin temp as a surrogate for core temp (base don an algorithm). I don’t think you could rely on that for ovulation measurements.
This is just my initial read of it, so I could be wrong…
Very little variation
And I seriously doubt most TR users need to worry about birth control.
Well, my observations are only what the device is showing. But a fast rise in temp (accumulation of heat) doesn’t seem to make sense to me (a non scientist) unless the body intended to do it, which makes no sense because it works so hard to keep itself cool while exercising. Guess it depends on what quickly means.
I found the first article by googling “time course of changes in core temperature during exercise”. It was the first study that popped up. The third one includes this diagram.
The X axis isn’t labeled, but the text says “heat balance is achieved within 30 – 45 min of steady-state exercise, with the greatest rate of body heat storage, and therefore increase in core temperature, occurring in the first 15–20 min (46) (Fig. 1).” Your CORE data seems to lag about 20-30 minutes behind that expected time course.
In any case, I don’t think that the body “means” for core temperature to go up during exercise - it just seems that it can’t fully prevent it, because based on the figure at least it takes a while before heat dissipation increases enough to match heat production.
CORE uses a thermal energy transfer sensor which we make in Zurich. It is not a ’skin temperature’ measurement (although we can also record this as well).
There are details about this sensor works on our website here: The technology behind CORE
It is nice to see the graphics and a suggestion is to do some hill climbs and map the core body temperature against the elevation.
The ’speed’ of core body temperature metrics is a slow moving metric, especially when you consider that power and HR can change rapidly. Core body temperature is tracked in real-time with live data and when you analyse the data you will see that the human body continually tries to regulate (e.g. with sweat) and aide cooling. Many factors impact the core body temperature of a person and our data from over 5 years of R&D shows that ‘effort’ intrinsically impacts core body temperature.
For example, we can see the rider data collected during the Tour de France and the Giro de Italia that show when cycling uphill, the rider effort increases and core body temperature increases. When the rider effort drops the core body temperature follows. A rider can cycle with high intensity downhill which would keep their core body temperature high though the wind and cooling effect would make it less like that they cross their threshold.
Regarding ‘actionable data’, this is a good question. Athletes will use core body temperature data for training (heat-block-training) which stresses/conditions the body for improved competitive performance. While racing, there can be different approaches to interpret the data. For example, athletes participating in extreme endurance events can use core body temperature data as a guide (like FTP or HR) and manage their temperature so they don’t exceed their threshold which would put them at risk of heat-stress and degraded performance/recovery. In a stage race, a lead-out rider in a group can use the data as a guide and switch turns in good time. Riders can also ‘actively cool’ which could be reducing power, pouring water over their body or opening up the jersey to increase wind-flow.
Those of you that have been using this device - how are you getting on @gpl @cinzanoframepump
I’m waiting for mine to arrive from Switzerland (@gpl - you’re in Oz too aren’t you, what sort of shipping time was it for you?).
I’m pretty excited about using it, particularly over here in the summer heat. I expect I’ll be using it retrospectively in the first instance but I see there is a developing area of using it to guide training which looks cool.
I’ve been really enjoying seeing under the hood (bonnet). I pretty much demanded a buddy of mine also get one and we have been enjoying doing indoor workouts (chicago) and talking about the effects of fans vs no fans, humidity, heat, etc.
Some insights: Core temp takes a while to ramp up, and a while to also come back down. Right as you get off the bike from a workout, core temp will still increase for a little while, sometimes faster than when riding. I didn’t expect that.
We’ve taken this writeup, and been doing workouts entirely uncooled, and sometimes purposely warmed up. I bought a thermo-hygrometer so I could see the actual conditions and have been keeping the humidity up with a couple of ultrasonic humidifiers. Amazon.com
I think I have been able to find a core temp above which my power really falls off. I’ve attached a couple of screenshots for a sample 10 minute interval on consecutive days. One done while not hot, one while at around 101f. You can see the difference.304 255
I’ve found that the heat and humidity doesn’t bother me nearly as much. The value of this in Chicago in January is of course debatable, but it is fun to try different things and learn what’s going on while getting through the cold season inside.
WKO5 has a coretemp dashboard, and you can add coretemp in just about any graph WKO generates. I’ve been adding screenshots to my rides so I can look back at them later. If anyone wants to take a poke at the rides with screenshots, my Strava is Strava Cyclist Profile | Patrick McNally
The device itself is really well done. You never notice it. One thing you should source is a strong refrigerator magnet. To erase the history stored inside the Core, you swipe the magnetic charger against the back of the device itself. If you happen to forget to do that and are suited up to ride, and you want a nice iOS app graph of your ride without past history, you will need to strip down and erase the history with the charger UNLESS you have that fridge magnet. With it, you can erase the history through baselayer and jersey and whatever else you’re wearing.
Highly recommended device. I’m enjoying having it and having a truly new metric. It’s been a long time since there was data completely new to understand and integrate.
Some podcasts have covered it
10:00 in
https://overcast.fm/+SJWHYYYOs
Around 44:30
Entire thing
https://overcast.fm/+SJWHvtwvM
10:00 or so
this too
This is a good one too
Feel free to message or ask away
https://corebodytemp.com/pages/heat-training-for-sporting-performance#03 forgot the link
