Can't Calibrate TruTrainer Smart Load -- No Speed
Hello!
I’m unable to calibrate my TruTrainer rollers in TrainerRoad – the speed gauge doesn’t work; no matter how fast I pedal, it doesn’t go above 0.1 mph.
When I connect the rollers to my head unit using FE+C, the speed shows up correctly.
I can still do workouts with TR, power and resistance control seem to work fine, calibration is the only issue.
Any advice?
Thanks!
  • Eric
My advice would be to contact support and see if they can figure out what is going on. support@trainerroad.com
Other than the good recommendation to contact TR support, what do TruTrainer typically recommend or offer for calibration?
  • You can calibrate with whatever they normally recommend and that data will be used when you load TR for any workouts. It’s not necessary to calibrate specifically with TR.
Thanks. I can do a spindown calibration with the TruTrainer app. It’s a bit of a pain, but not insurmountable, and what I’ve been doing so far. I thought maybe I’d encounter someone here who had experienced the same isse.
The TruTrainer people suggested that the data protocol for trainers had 2 different fields for speed, “virtual speed” and “actual speed”; the rollers apparently supply the actual, so maybe TR is only looking at virtual.
Copy that. See what TR support has to say and go from there.
@fix did you find a solution to the calibration through TR? I’m finding same issue.
