Best method to adapt for a 9 day “week”
Hello. I’m a full time firefighter and have a bit of a different schedule than most other athletes. I’m on a “24 on / 48 off” schedule so it’s easier for me to try to schedule around a 3 day “cycle”. So think multiples of 3 (3,6, or 9 days at a time ) I don’t ride on the days that I’m on shift so I’ve decided to go with a 9 day “week” where I’m able to ride 6 days and rest 3 days. I usually do strength training at the firehouse and this also seems to be a good way to allow for recovery since I’m turning 50 in a couple months. I’m wondering what the best way to go about doing a 9 day “week” in trainer road. Currently, I’ve created a training plan base on a gran fondo in June and I just drag and drop the workouts on the calendar to fit my schedule. Is there a better way to do this? Will this affect the AI in a counter productive manner? Thanks any help would be appreciated.
Why not just repeat 3 on 1 off?
Hard
Easy
Medium
Off
Repeat
Or
Hard
Medium
Easy
Off
Repeat
The 3 day block is quite popular with several teams (see uno-x mobility) so implementing it for yourself seems reasonable.
Generally they go hard workout, medium workout, long easy z2.
You might have to play around with it a bit but if you structure it to do your hardest sessions on the day you are most recovered and then fit everything else around that you should be in a good place.
Hey there and welcome to the TR community!
The 3-day block as suggested above is a great idea – I also think dragging and dropping your workouts as needed to adjust your schedule works here.
It won’t have any negative effects on Adaptive Training, either. :slight_smile:
I’ll stick with my current training plan and just keep drag and dropping on the calendar. I wish there was a way to adjust the calendar to a different week cycle as opposed to the 7 day norm. Hopefully, this is a feature that could be implemented in the future. Doesn’t seem like it would be too difficult (from a programming standpoint) and considering that there are other that are doing it (from pro athletes to masters athletes to shift workers) … this would be a great benefit for that population. would also make an already great program even better and set it apart from others. Thanks for the help!
Fellow firefighter here. I’ve spent quite a bit of time trying to think of the best way to handle this scenario. The best I’ve come up with for me is a 2 on/ 1 “off” cycle.
The day before shift is when I do my intervals and it’s also my longer rides. Not ideal I know, but it’s the only day I can guarantee I come into it rested.
It might look something like a 1hr TR outside workout then 2 hrs of singletrack.
On my shift day, I do 1 hr Z2 and strength training.
On the day after shift, I leave it open and base it on how much sleep we get. If we sleep through the night, I might hit 2-4 hrs Z2. If we run all night, I’ll make it a rest day. If we run once or twice after midnight, I might do 1 hr Z2. I base it off how I feel that morning.
