Assioma not working after pedal replaced
I’ve raised a support ticket but just wonder if anyone else has had this issue.
I recently received a new left hand pedal from Favero as part of their recall and I have paired it up to my original right hand pedal in their app.
It shows in the Assioma app correctly as a dual sided PM but in TrainerRoad it is only functioning as a single sided PM.
I tested on my garmin by pedalling with each leg individually and it works as a dual sided PM in there too which leads me to think that something has gone on in the TR app since I replaced the pedal.
Anyone else had this and any ideas while I wait for a response from support?
I should add that it is driving me mad, I can’t stand single sided PMs and it really gets in my head when I’m trying to train.
I could be wrong here, but I’m 95% sure TR (and many other indoor training apps, if not most) only use the LH side PM in any dual sided setup, functionally making them single sided (the apps take the LH side number and double it if i’m not mistaken).
Anyone here on the forum or the TR mods can feel free to tell me i’m wrong, as I’d much rather hear that the apps are using both sides on my assiomas, but this is what I believe i’ve read about in the past.
I don’t think that’s correct and I’ve never heard that. I believe TR uses dual sided PM but only displays one reading, as in not L/R. If I recall TR sees no value in focusing and displaying power L/R. Meaning that they could display L/R but choose not to. This indicates that TR does use L/R when determining power.
@Nate_Pearson
Took me a few minutes to find WHY I made that claim, but the reason for it stems from this video from @gpl, as well as my findings within indoor training apps…
At about 3:30 in, he alludes to this within the context of Zwift and Bluetooth, but I’ve also noted when using my assiomas via ANT+ with powermatch enabled on TR, only the ANT+ ID for my left pedal is displayed in the devices screen…
Again, I could be wrong in my assessment, so it would be awesome to get @Nate_Pearson’s, @Jonathan’s or anyone else at TR’s verification… but this is the suspicion I’ve operated on since watching Shane’s video and my experience with apps i’ve used (TR, Zwift, Fulgaz, etc… all of which only display my Left side ANT ID…)
The ANT ID is suffixed with an L so perhaps this is what’s happening. The weird thing is that I never noticed before. Unfortunately now that I know it is going to drive me insane. Might have to switch back to using the tacx neo for power.
Is that within the context of the TR devices screen? I’ve not noticed the L in particular in TR, only that the ID number itself matches that of my left pedal. When i’ve looked at the ANT+ information within the Assioma app in the past (which typically is only for the occasional firmware check OR when charging my pedals), it denotes 2 unique ANT+ ids (left vs right pedal).
It’s been some time since I verified either one, so maybe that’s changed, but i’m not near my bike at the moment so cannot confirm.
Yes that’s only within the TR app.
If that’s always been the case then firstly that is pretty rubbish really and secondly I need a way to go back to the time that I was ignorant of this.
Not interested in L/R power but I do want total power and not just one leg.
Just forget everything you’ve read today so far!
Besides there’s always a chance that TR will debunk EVERYTHING i’ve said anyway! :crossed_fingers:
One further follow-up on this as I found it just now in the Assioma app because I am currently charging my pedals so I had it open…
I never had actually seen this option before so I had never changed it and suspects it defaults to the Unified option seen above… note the descriptions for each setting…
  • Unified channel… most apps require this…
  • Dual channel… both pedals must be paired…
Given this new finding, I switched my pedals over to Dual Channel to check out the devices screen… On neither BT or ANT+ did the TR app recognize a 2nd pedal to pair to (checked against BT on iPhone and iPad and ANT+ on Mac).
Hey guys!
Depending on what model Assioma pedals you have and whether you use BLE or ANT+ connection the following applies:
Favero Assioma Pedals have two different models.
  1. Favero Assioma Uno Pedals: Left-sided pedals that double the power reading.
  2. Favero Assioma Duo Pedals: Left and right side pedals that send two different power readings.
Pairing Favero Assioma Duo Pedals over ANT+ will send a combined Left and Right Power reading.
Pairing Favero Assioma Duo Pedals over Bluetooth (per the screenshot @Will_Peters posted) will send power readings depending on the setting:
  1. Unified L: Right pedal is ignored; power is doubled from left pedal and sent to TR.
  2. Dual-channel L/R: You only pair one pedal in TR, but power comes from both the left and right pedals.
:point_up_2: I don’t think this is true?
I believe that the power from both pedals is combined and the total is sent via the left pedal.
I don’t think the power from the right pedal is ignored.
Pretty sure “Unified L” is the correct setting to get all the power data from DUO pedals to TR via Bluetooth.
I believe with “dual channel” only half is reported as TR only doubles readings from UNO pedals.
Hey there,
This info is accurate as of our latest testing using Assioma pedals with TR. If this changes, we’ll be sure to update it. :slight_smile:
I really think you are mistaken here but I’ll test tonight and confirm :+1:
I think if I pair via Bluetooth using “unified L” and unclip from my left pedal the power from my right pedal will be reported.
If I’m wrong I promise I’ll say so :grin:
Hey @kevistraining ! Please let us know how it goes :slight_smile:
That way, if needed, we can update the info.
Sorted!
I set to unified channel rather than L/R and now it’s working as it should. Thanks all
Yayyy!!! :partying_face:
