Hi
I have a pair of assioma shi duos power meters pedals (spindle into pedals). I put them into 105 pedals. I Have them about a yr and then the right hand side is creaking if you spin the pedal.
I thought the pedal body was be the issue but i swapped them into ultegra pedals and still have the noise.
The original bearings degraded quickly in my case (duo-shi). I had to get a replacement set from Assioma directly. Next time around I’ll get an aftermarket set of bearings. I suspect something with the design …
