Anyone have the Neo 2T?
Thats what I would do if I were you.
alternatively I do all my indoor (and mostly all) my training on my neo and then know that my 4i typically reads 8-10 watts low, so I know that for example my “Neo FTP” of 300 will technically be in the 290 area for the crank power. However, I use this number is a soft guide and from actual races I know running 220 watts on the 4i this year with a 285 FTP ish will yield a solid run time, so if I gain significant wattage I know I can safely punch above 220 to a point. Anyways, I use a combo of both to structure my actual pace, but I make sure to use tests or old race experiences to “verify” the numbers and not just rely on the ramp test value.
Trust but verify.
When I started I relied solely on RPE and still rely on RPE for my races, while I use my power numbers to “check in”. To be honest though, I think I could ride anything shorter than a 70.3 tri ride blind and nail the wattage +/- 10 watts, while I would never want to try that on a longer race (hence power meter checking is much, much more important)
Having a consistent 30 watt discrepancy (underreporting) between my new Neo 2T and other power devices: Vector 3, Vector 2, and Kickr. Still waiting for a resolution but thus far been pretty disappointed with the Tacx Neo 2T.
Felt the same but mine was the wheel slip. Returned it and got the H3 for 1/2 the price. It is not perfect but very solid and cannot find any major faults.
I got my Neo 2T today. Did my first TR ride this afternoon (DC Rainmaker analyser file at the link below). As well as TR, I connected my Vector 3 dual sided to my Edge 1030. There seems to be a 15w discrepancy on the average power, with the Vector reading consistently higher. Thoughts please? Is this a problem with the Neo reading low, or the Vectors reading high? Where do I start? I think the overall difference is outside the tolerances even if one device was at the top end and the ither at the bottom… Advice gratefully received!
https://analyze.dcrainmaker.com/#/public/f8d9fbd7-9a5b-4257-4afd-d7ba9e7b5d71
I’ve been having great difficulty getting two sets of data into one place where I can compare easily but on a recent ramp test my 2t appears to be within the error bars for agreement with my p2m…and generally much better than 2% allowance on both. They are close enough that I have confidence using either.
I’ve got a dozen or so hours on a new Neo 2T (shipped from Garmin, Kansas on Dec 20). It has been very close to my crank based SRM, generally 2 or 3 watts average above the SRM on 10 minute threshold intervals at 200w.
How is power accurancy with 2T in current time. Do you get any new firmware to fix these 15watts drops(i’ve heard a case form where some report higher is wattage more distance in correct numbers)? will it be in future fiex? How about ERG, i heard is now 2second input and output?
I’m considering to buy a unit. But in general if i choose much cheaper Elite Direto X, i got super power accurancy as power meter is integrated in this trainer (so, the said). it’s just more laggy?
Just a quick update to this, after returning the Neo 2T I picked up a Kickr Core. I did a ramp test on it tonight and the power is lining up within like +/-2 watts against my Favero’s.
You good with the NEO 2T now??
Hello fellow riders,
I am in the market to buy a good trainer that will last for years and with the main goal to use it for structured programs like TrainerRoad (it would be my first try with this app). I have reduced my options to the wahoo kickr & neo 2T, maybe the wahoo kickr core because I don’t see that much of difference between the two kickr’s. Anyway, what is the general consensus as of today? It seems, if price is not a problem, that the neo 2T is a very solid option, being accurate, great road feel and silent. But I’m reading here and there that in ERG mode it might not be ideal due to its harsh responses. What are your thoughts, for those who are using it since a couple months now? thanks !
I would describe mine as “very responsive” rather than “harsh”
I use it 6 times a week for a couple of months now, it does a great job. The only thing still missing is cycling dynamics, you have left-right balance though.
Thank you, @gpl !
BTW was the 2T affected by the “accuracy at high fly wheels isssue”? I am always using the 20-25 km/h range and have no additional power meter, so I couldn’t tell. I know you did some elaborate testing with the Neo 2…
Thanks for following up on the firmware update @gpl! Honestly the ghosting issue was a non-issue for me since I use TR 98% of the time and FulGaz/Rouvy/Zwift for the other. Using TR and this trainer has been very positive with good results after a few months, still quiet and efficient and no slippage either that few have experienced.
This is just a small sample, but I personally know 4 different people from different parts of the US who have had enough trouble with the new KICKR in the last few months that they have returned them for replacements and sold the replacement new in box.
It seems like the 2T is over it’s teething issues and reliable now.
Again, a small sample, but very significant in my small circle.
The Neo 2T has been working great for me on mostly TrainerRoad and some Zwift over the last month. It tracks very closely with my SRM on the bike. In erg mode, I’d agree that it’s quick and smooth but not aggressive. The Neo 2T is more forgiving than my Kickr V1 when a phone call or something interrupts an interval – it ramps back up to power smoothly instead of acting like a brick wall like the Kickr did.
I thought the issues with the 2018 kickr had been solved for the most part?
Not in my circle
We still see Clickr’s happening in the Wahoo FB group. It may be better, and even possible that the continued bad ones are left-overs, but repeat units for some people getting them direct from Wahoo seems to indicate it is still happening for some people.
TacxFaqx did some testing and compared NEO 1, 2 and 2T with regards to their linearity, i.e. accuracy of power in erg mode vs flywheel speed (gearing+cadence choice). Almost any trainer out there exhibits different levels of accuracy for different speeds. According to TacxFaqx, Tacx already adressed this for the 2T with the 0.0.31 firmware update (0.0.34 only fixed the phantom watts issue of the 2T).
Here is the link, the 2T is performing pretty darn good:
https://tacxfaqx.com/knowledge-base/linearity-showdown/
It’s an interesting analysis, but it has two flaws.
First, all 3 trainers apparently hit the resistance floor on the longest gears, and can no longer meet the pedal-measured power target. That’s not a linearity issue, it’s a trainer limitation, in a situation that most users would rarely get into (100W on 50/12 at 90 rpm, for example).
Second, the power level used (100W) is not near the average power used for most trainer usage. A similar test at 200W would probably yield more useful data, and also indicate if linearity changes with the overall power level.
