Am I the only one not unhappy with the new TR AI?
Manual, but based on a standard general base plan (2 x sweet spot, 1 x over/under, 1 endurance). I’ve never really bothered with plan builder, so can’t say if one approach would be better than the other.
I was admitted into the beta December. At the time I was really battling with threshold type intervals, including over unders. AIFTP gave me a significant bump, which resulted in my failing a couple of workouts. Indicated this in the post-ride evaluations and FTP was dropped down.
Suddenly the workouts were just right and I stuck with the program. Long story short - I now fairly comfortably do Sweet Spot intervals at the same wattage where I failed my threshold workouts in December, so I am definitely stronger. Most important, this is also reflecting in my racing results. It seems after a bit of a rocky start the system calibrated and and is now working extremely well for me.
I’m struggling with the “adaptive” part of the training plans.
My weekend group rides are consistently 4+ hours long with high TSS. When building the plan, TrainerRoad flags this as a “High Training Load” warning, but that’s where the “intelligence” ends.
The problem: The system does not proactively scale down or “absorb” this load into the rest of the week. After a massive Saturday, the plan still expects me to hit high-level intervals on Tuesday or Wednesday at the original intensity. It doesn’t automatically downgrade a Level 5 Threshold workout to a Level 3 to account for the actual fatigue.
My question: Is there any way to make the algorithm recognize that a 4-hour hard ride should automatically trigger a reduction in the “Progression Levels” or intensity of the following midweek sessions?
Welcome to the forum! :partying_face:
I just took a quick look at your calendar, and there are a few things I’d like to clarify.
Are you okay with discussing those details here in this thread?
Yes of course, thanks
TR AI actually does do this. :backhand_index_pointing_up:
Those red days on Sunday and Monday are there to warn you about training after that long day on Saturday. Since you don’t have a training plan in place, though, there’s no training to modify.
By default, we will turn yellow days into easy rides, and we’ll recommend you rest on red days.
Additionally, we’ll alter the intensity of upcoming workouts if you have recent fatigue that warrants it.
If you find that we aren’t being careful enough with fatigue detection (this is almost never the case with our athletes), you could change the training approach of your training plan once you have one to something like conservative or balanced.
Side note: if you’re doing hard enough rides that you need to dial down training 3+ days later, I’d say that you’d probably be better served avoiding that much intensity on one day.
Let me know if this helps and if you have other questions. There’s a lot going on under the hood with TR AI, and there’s some nuance. If you want to chat some more, just shout!
Thanks for the follow-up and the insights into how TR AI manages fatigue. I appreciate the explanation of the Red/Yellow day logic.
I’d like to clarify my goal: I’m looking for a way to let the system take the lead on the “recommendation” side. My ideal experience is that when I open TrainerRoad after a high-volume weekend, the software—knowing my fatigue levels—proactively suggests a scaled-down version of my midweek intervals.
As an example, I am attaching file example. As you can see in the image:
  • Even during the initial setup of a customized adaptive plan, the system flags a “High Training Load” warning.
  • I have tried reducing the hours of my Saturday group ride in this menu, but the warning remains.
  • Instead of just showing a warning, I believe the “Adaptive” AI should proactively recommend fewer training days or even offer to eliminate specific sessions to balance the total weekly TSS.
Currently, it feels like I have to manually intervene by changing the “Training Approach” or choosing a “Workout Alternate.” Ideally, I’d love for the algorithm to notice the 550+ TSS week and automatically adjust my next Threshold or Sweet Spot session to a lower Progression Level that matches my current recovery state.
I value the structure TR provides, but as a club cyclist, long weekend rides are a non-negotiable part of my routine. I’m looking for a way to integrate them so the plan remains effective without requiring me to make the technical coaching decisions myself.
Is there a specific setting I might be missing that allows the AI to be more “granular” with these automatic intensity adjustments from the planning stage?
We start you with our recommended training volume in that schedule step of Plan Builder. If you add enough volume that results in a fatigue warning, as shown in your image, you just need to start pulling out volume where you can in the same way that you added it in the first place.
It sounds like you’d rather have us keep the balance of recommended training stress as you modify your schedule. Is that right?
In that situation, if we started you off with the right volume for you, and then you added 6.5 hours of unstructured outside riding to your plan, you’d prefer that we automatically pull volume from somewhere else in your plan to keep things balanced. Is that right? In your case, I imagine you’re expecting us to remove that hard indoor workout on Tuesday..
Let me know if this is what you’re looking for.
Hi Eddie,
Yes, that is exactly what I’m looking for.
Since I’m using a Masters Plan with only two intense days (as shown in my previous screenshot), those sessions are very important to me. However, if I add my 4-hour group ride on Saturday and another ride on Sunday, I expect the system to recognize that the overall stress is too high.
Instead of just giving me a warning, I would prefer if the Plan Builder or Adaptive Training automatically:
  • Remove or scale down the hard indoor workout on Tuesday to keep the plan balanced.
  • Suggest a rest day or a very easy recovery ride if the weekend volume was particularly high.
The goal is for the software to act as a coach that “pulls volume” from the right places so I don’t have to guess or manually delete workouts myself.
Is this something the current AI can be configured to do automatically, or is it a feature you are considering for future updates?
The software does this to a certain extent already.
What I was suggesting was an adaptive scheduling step in Plan Builder, but what you’re talking about is plan adaptations on the fly, in real time, which we already do.
If you have a high-stress period of training, we’ll make adjustments to your upcoming schedule.
Having a hard ride on a Saturday and riding on Sunday won’t always affect Tuesdays, though. It depends a bit on your recent training experience as well as your Training Approach settings, but if Sunday’s ride isn’t hard and you have Monday to recover, you should still be able to get a workout in on Tuesday.
Again, this is all dependent on a lot of different factors, but as I mentioned earlier, I’m seeing this working on your calendar. Last I checked, you had red days on Sunday and Monday after a hard Saturday ride. If you had training scheduled on either of those days, we would have recommended changing it. It’s possible that your Tuesday workout changed, too, but I haven’t dug in close enough to verify yet.
I’m sharing our Help Center article on Fatigue Detection below. Take a look and let me know if that helps clear things up. :+1:
Switch to a three day Masters Plan. Tuesday and Thursday are your indoor hard workouts, extend the endurance ride as your Saturday 4.5h Group Ride.
I think youre asking too much and I also think its unfair. If you want to train unstructured, dont use software that feeds you with structure plans.
Or could go train now and pick your workout level a couple days per week and go nuts on Saturdays. Kinda “structured/unstructured” if that makes any sense.
Joe
I’m not happy with that and that led to resign from this service for now.
It’s not that I don’t “get” the new AI or that I’m afraid of change. What really bothers me is what happened in my support case and how it was handled: I ended up with what was essentially a double time FTP was increased (1 week before this “upgrade” and when it was released), it drove me straight into fatigue, and support was not able to give a clear, convincing explanation for why the system did that. Instead of an honest breakdown of where things might have gone wrong, I just kept getting polished replies (seems AI based) trying to justify that “this is how it should work,” which never actually addressed the core issue that my training load had clearly become unsustainable.
What was TR response to your case exactly?
Support told me that the new AI FTP system didn’t “overshoot twice,” but just did one small, normal recalibration (a few percent) based on my recent power, and that this is expected with the new model. I’ve used AI FTP for about three years and never had it plan workouts in a way that I’m supposed to mark them “Very hard” just to make the system back off. I expect the AI to be smart enough to keep progress smoother. For me this “double jump” still felt too high in practice, and support basically didn’t accept that as an AI issue and refused to explain the new calculation. There was a long debate that ended with me removing subscription.
If you’re interested, I’d be happy to take a look at your training history and let you know my thoughts.
Just shout if I can help with anything!
@eddie sure, please do and sent me analysis in pm
I just sent you a DM with some explanations for the things you’ve referenced in your post. Take a look and let me know your thoughts.
