Additional Adaptations Before Next Activity
OK. Very interesting. My two weeks of Solo Rides did cause a big jump up in PL adaptations in my plan’s future workouts, which, funnily enough, is what I think would have happened if those rides’ IF and TSS were properly taken into account. So you’re saying it’s a bug, not a feature :-).
Correct! :slight_smile: This is a bug we’re looking into. However, I can verify your two weeks of Solo Rides did not cause a jump in PLs.
Are you saying you can do that or have done that? Can you go back and see what my plan was before I accepted those big increases in PLs? I delayed accepting the adaptations for a week or so because they were so big and unusual, but after I did accept them, there was no way to go back and see what the plan was before I accepted them. If you can go back and undo my accepting the adaptations you will be able to verify what I’m saying.
Any chance of getting a start date notation that stays and doesn’t move? Making it easy to see on the calendar when a plan started.
Yeah, that’s frustrating, it really should track that change history
What I meant to say is that I can clarify that Solo Rides can’t cause jumps in PL’s. Only TR Structured Workouts can.
I can’t undo things once accepted on a plan, but I heard back from the team and good news! The issue you reported should be fixed. If you were to renew after the summer’s over, you shouldn’t be running into this any longer.
I’ve definitely taken the feedback! :slight_smile:
OK. So, it sounds like the big increases in PL I saw after two weeks of nothing but unstructured “Solo Rides,” was due to a bug. I was hoping TR was now using Solo Ride data and generating adaptations based on those, but evidently it isn’t yet.
So, Solo Rides seem only to be included for fatigue. When I do a solo ride, should I simply identify the existing plan workout as a Solo Ride and associate the ride with that, or should I change the plan workout to one more akin to my actual Solo Ride and associate the ride with that instead? To put it another way, does it matter what the plan workout is when I turn it into a Solo Ride? .
Swapping the TR workout to a Solo Ride is the best and easiest way when following a TR Plan :slight_smile:
The Solo Ride workout card has instructions as to what to aim for when swapping a TR workout for a Solo Ride so that at least you’re consciously riding in a way that still exercises the energy systems scheduled for the day.
Example of instructions:
Note: when you manually add the Solo/Group Rides, the instructions aren’t there.
If I understand it correctly, this says to do a Solo Ride that is roughly similar to the scheduled workout, which makes sense, but it is the inverse of what I’m asking. Does it make any sense to replace a scheduled workout in the plan with a workout that more resembles the actual Solo Ride?
If you didn’t follow a SPECIFIC workout leave it as a Solo Ride
To do a Solo Ride, you need to convert a workout in the plan to a Solo Ride. (right click on it and select Solo Ride). Then when the ride is done, it needs to be associated with that Solo Ride. The questions I have is does it make any difference to TR how the workout that was converted to a Solo Ride relates to the actual ride. Should a plan workout be changed to a workout that more closely resembles the actual ride?
From what I’ve seen, if you convert a workout to a Solo Ride (or Group Ride), TR will add the one of the six ride ‘instructions’, which @Caro.Gomez-Villafane posted earlier, which most closely matches the expected workout intensity of the originally planned TR workout, and also include the recommended length and TSS.
I have actually added IF and TSS as data fields in my Garmin so that I can monitor, and manage, my progress during the ride.
Why are you converting it to a Solo Ride? Why not just do the workout?
I ride mtb and gravel outdoors and am not currently training for an event or race. I only do indoor/structured workouts when riding outdoors is not convenient, which is typically over 3-4 winter months. I’m now only riding outside, not doing structured workouts, and am trying to understand how TR might work with that and how that might benefit me. There does seem to be a platform that does that, “The Breakaway” app, which has just been acquired by STRAVA, but it’s only on iOS atm.
