Zwift's New Ramp Test (FTP)
I have no idea how you can make this claim.
Knowing someone’s W/kg says literally nothing about their ability above or below FTP or any related duration. It’s a single data point. That’s it.
I have a nearly identical W/kg to 2 local riders. One is the same weight, but we have very different power profiles. Another is heavier, but we are more alike in power curve. Point being that W/kg around FTP is not all telling.
There’s no way to look at that one point and make any accurate claims to their ability outside the FTP equivalent.
I am not sure that is true. I could do a number of sessions higher than my FTP, say upping my FTP by 10% but that would not be the right to do and would not be sustainable over the long-term,
Ah sorry it was the sentence "But I’m not aware that most of those prior ones were used to determine FTP in the same way that TR has done. " confused me, was just pointing out there were a lot of prior ones were used to determine FTP in the same way that TR has done.
As Oscar Wilde said " “Imitation is the sincerest form of flattery that mediocrity can pay to greatness.”, so there will a lot of coaches (and gplama) flattered that TR and now Zwift have copied their principles, after they both copied Andrew Coggan’s 20min ftp test, after sufferfest implemented it first … just have wait until they catch up with the rest of the 2008 book
As I recall from when TR was going through the process of developing their ramp test, it sounded to me like what they did, albeit on a grand scale, was compare ramp test results for individuals to their results on the ramp tests to come up with the formula. They then tweaked the formula at least a couple times during the beta. This is a sound logical approach and it certainly appears they have done a good job of getting the ramp test numbers to generally match one’s 8 or 20 minute numbers. But this approach is not exactly hard nosed human sports physiology science. Its a math exercise. You’re taking “tests” you can’t really verify and bench marking them against a new set of tests you can’t really verify and then doing trial and error math to make the results match. That being said, it is more than good enough for the vast majority of TR users and I’m for one quite happy with the results (the formula that is, not my actual FTP number :wink:
It would be interesting to see how Zwift came up (or is coming up) with their formula. My guess is they don’t have as big a data set to work with as TR does but their data set may be more than big enough to do the plug and play/trial and error work that TR did too.
I think there Zwift used the recommended by coaches (see my links above) 0.75, where as like you say. TR did an entire beta thing to get peoples Ramp Test to mach 20\8 min tests, the only think that strikes me is there are a lot of “over tested” \ “under tested” posts, the the coaches that use the 0.75, prescribe does 20mins at FT / 0.95 afterward to confirm new FTP … maybe TR should build that into their training plans
The idea of this is the “novice riders” are more likely to fail doing the ftp test, rather than the ramp tests, but if they are told … this is your ftp, you should be able to at x … they are more likely to achieve it
My understanding is that although this might have been the starting point, they also looked at the data of workouts completed after the ramp test to see whether they were overestimating or underestimating for the majority of users.
Very true, but that wasn’t the point I was making, and you can remove the sentence from my post and I would be raising the same point
Yeah. As I hinted, my little joke didn’t land. I plan to keep my day job. :stuck_out_tongue:
Full disclosure, I will remove that quote since it is only serving to distract from the discussion I had hoped to have in this thread.
Sorry for that and other digression my comments have caused. Lesson learned.
FYI, there have been unofficial but popular ramp tests to determine FTP on Zwift for a while now. Much earlier than the TR ramp test. This Shane Miller guy has a video about it from Jul 2016.
See my post above where I provide links
Boooo… I liked the original thread title!!!
The actually thread title never changed.
But I removed the quote from the OP.
Except here we kind of do! We’re that awesome!
I hate the FTP testing /the end. If a platform can work out when your FTP increases without needing to test, that’ll probably be a winner.
TR has hinted they’re headed in that direction.
My son’s did the Zwift ramp test yesterday, and I am not impressed. It did not take into consideration their current FTP at all and started them at their current FTP within 1st couple steps. My boys are in the 100-125 FTP range. Had one of my boys do ramp test on my TR account and delete test later and TR is much better like we all know. Just my 2¢.
Yup, I expect some interesting results for those on the outside ends of the bell curve. Likely worst affected will be those with low FTP. The start level and fixed 20w steps may lead to premature failure. But that is just speculation on my part.
Exactly right. My sons tests lasted less than 10 min including warm-up that was way too high for a warm-up at their level. Zwift may make it better, but TR is much better. If I want eye candy, I can tie Zwift into the real work I’m doing in TR. JMO.
It is nice when you get an alert from Training Peaks to say your ftp has increased. Normally when I have done a time trial and then I ignore it as I have not done a 5 minutes all out beforehand.
I wonder if this will be at all similar to what Garmin does with their metrics and gives you recommended FTP’s after rides?
