Zone 2 in Heated Gym
Hi All
I know this was covered in June 2023 but the topic got off track from my query so going to ask a similar question.
I train about 7.5-9 hours a week:
Mon - Rest
Tues - 60-90 mins Sweet Spot Intervals
Wed - 2 hrs Zone 2 (using HR - keeping HR under 140bpm)
Thurs - 2 hrs Zone 2 (using HR - keeping HR under 140bpm)
Fri - Rest
Sat - 60 mins Threshold Intervals
Sun - 3 hrs Zone 2 (using HR - keeping HR under 140bpm)
So it’s a pyramidal style of training and every session right now is indoors.
I have no issue sitting on an indoor bike so motivation isn’t an issue for me.
I have a 300km one day event next year and I am not a natural aerobic ‘athlete’, hence trying to do a reasonable amount of aerobic/base work.
My query is this:
Wed and Thurs I have to train at my local gym with little to no aircon. My average power is about 130 watts over the 2 hour ride.
At home I average 150-160 watts as I have a fan and can open all the windows.
My average power at the gym hasn’t really changed in 5 months and I wonder if my fitness isn’t getting anywhere due to me overheating. Am I really improving my aerobic system if my power is 20-30 watts less than it should be due to the heat?
I can’t switch my gym training to home sessions and the gym aren’t going to change their aircon just for me so I don’t have any option but to train at the gym.
My lack of change is my concern…I don’t mind sitting for hours on an indoor bike at a low zone but I also don’t want to waste my time either.
Any thoughts on whether training at the gym is hampering any improvements I may get?..or any ideas on whether to just stick with what I’m doing or change something?
TIA :slight_smile:
Time on the bike is not wasted time.
You will probably get slightly less adaptations riding at 130w vs 160w but it’s still training volume and is still beneficial.
Heat training does have its own benefits as well, especially if your race is in warmer conditions but even in colder conditions it’s not wasted.
Extend the workouts if you have time.
Are you riding 30W lower in the heat because it’s too hard to ride at the higher wattage? Or are you purposely limiting yourself? I ask because I do 90% of my Z2 without turning my fan on. I just don’t like the fan blowing on me. I’ll use it for harder efforts but for Z2 I just suck it up and ride. So I wonder what would happen if you just ride normally at the higher wattage.
How are you measuring power in the gym? Are you carrying power pedals in and installing them on the gym’s bike? I guess it’s nice that the gym wattage seems consistent, but, unless it’s the same brand equipment you have at home, I wouldn’t assume they would match to any degree.
Has your home z2 wattage (at the same HR) increased over that period of time?
It came from having a test at my local University where they did blood lactate testing in order to see where my thresholds were.
The guy has a PHD in exercise physiology and it was his testing and advice that made me try to stick under 140bpm when doing endurance work
I find the Zone 2 rides pretty easy. My max HR is just under 200bpm so I could ride at 150 or 160 watts but my understanding is that puts me into a different training zone so the adaptation would be different?!
Hi
I use a Watt Bike at gym and it does feel harder than my Wahoo Kickr at home.
I sort of feel there is a discrepancy but as with any discrepancies, the lower the initial value, the less the discrepancy is. So even if the two bikes are 10% out, which would be a lot, it still wouldn’t make up for the difference in my power outputs.
I was trying to ascertain whether I’ve seen much change in my Z2 power…it’s hard to know as my first 3-4 months were all done at the gym and only recently I added home training into the mix (as my situation changed).
I have made a chart to track home changes and will update as I find :slight_smile:
Ok, I now see you’re doing these rides based on HR as the cap. Somebody with more experience can correct me but I do all my rides, even Z2, based solely on power. Meaning that my Z2 rides don’t have any HR zone I’m targeting and there isn’t a target I keep my HR under. To be honest, I don’t really even watch my HR during Z2 rides 99% of the time.
I discussed this with the Physiologist who did my testing and his opinion was that lactate production is based on heart rate…driven (amongst other things) by how much power you are applying.
He advised me to stick with HR when doing lower zone workouts but when I do higher threshold work, I could switch to power as my prime metric.
No idea if this is completely correct or not but that’s why I’m sticking to a HR for Zone 2 work.
Having said that, as I mentioned in my post, my power output is notably different if training at home or at the gym - hence me wondering if I am not gaining fitness with heat inhibiting my power output.
Those zones don’t really matter, see the post below from the man after who those zones are named. If you have a hard session planned the next day just go by rpe and not worry if you are some time in zones 1 to 5 for brief moments
In my experience I can do the same power in a gym as I can at home, but it’s miserable. I did two RAMP test the same day switching power pedals and got a result within a few watts off the home session.
So the problem is RPE, if you can’t use a portable fan and they won’t let you use their spin class equipment (which does tend to be airconned) then I would keep the session high intensity and short.
This might be good advice outdoors, but the heat is elevating your heart rate artificially not the muscle work that produces lactate.
Can you take your bike to the gym, change there and ride outside?
Can you share your calendar and what plan you’re on?
Your heart rate is elevated because of the heat, not because you’re in a different zone. This is one of the reasons it’s better to ride by power with heart rate as a secondary metric.
Try riding higher and monitor RPE and how you feel and recover. If it doesn’t impact your other workouts or tire you out too much, riding at the higher power will be better from a training and adaptation perspective. If it’s too much, keep it lower.
As others have said, you do acclimate to doing work in hotter temps. By mid summer I can do hard workouts in 90+ deg F temps with high humidity, but the first couple times out always suck …
In terms of keeping cool at the gym,
Have you got a really cold drink ( with ice cubes aplenty) or maybe some way of putting some ice blocks ( the ones you can refreeze and reuse) inside a towel and place on your back?
Hi
If I’m in the gym, my HR decouples due to the heat. At home, if I sat at 150 watts, I could sit for 3 hours at the same HR.
My FTP is 220w so 55% of that would be 121 watts and 75% would be 165 watts so that’s a pretty big range.
As mentioned, 150-155 watts I can hold steady HR for the whole work out at home. At gym it’s down at about 125 watts to stay more stable but it depends on the gym temperature that day.
This is interesting…so are you saying Polarised training or Pyramidal training aren’t things as zone training isn’t a thing?
Hi
I asked about a fan but that’s a no as they don’t want you ‘blowing your sweat around the gym’.
When I’m training, there’s usually a spin class on so I can’t get in there which leaves me in the gym.
My issues is on Thursday mornings, I have more time to train…hence the 2 hour early morning fasted session.
I do an intense shorter session on Wed late afternoon so usually my legs are a bit achy Thursday but I could switch to two lower sweet spot sessions and reduce the Wed session and increase the intensity of the Thurs session.
I’ll have a think…than you :slight_smile:
You will need to educate me as physiology isn my strong point…so if heat elevates your heart rate, does that mean you don’t produce more lactate as your heart rate increases?
I’m asking as if I train in the heat…even outdoors, I reduce my power to stay in my HR zone if I am doing a low level steady state ride.
If HR is irrelevant to lactate production if elevated by heat, I can speed my steady state rides up quite a lot. Last time I did that, I was 20-30 beats higher so ended up noodling pretty slow.
I could take my bike to gym and then cycle outside but I get to gym at 05.40 and train at the gym to avoid being outside in the dark and rain. I’m probably being a bit wimpy but I then have to clean the bike before putting it away and I’m not sure where I would do that.
Hi
I think I would be fine riding at 140 watts in the gym (maybe 150 watts) for a few hours if using RPE.
I asked someone else this as trying to get some clarity on an area I don’t know, is heart rate not important when looking at lactate production please?
I ask as I thought/assumed that lactate production was the result of elevated heart rate which comes about by elevated power from through the legs. As in, we produce lactate when our heart rate elevates to a sufficient high rate that our body doesn’t have time to use fat so switches to carbs which is what produces lactate as a by product of this elevated heart rate.
But what I’m getting from quite a few people on here is that heart rate isn’t that important physiologically when looking at lactate production, hence using RPE to understand if that body is creating or using lactate when training.
Any chance you can clarify that please?
