Why is my ramp test so low?
If your training was reasonably consistent before and you’ve had some sickness, it’s very possible that you weren’t up to full speed when re-testing using the ramp.
If you feel like you can adjust up, great. That’s sort of built into TR, you don’t have to be a slave to your test result if things are too easy/hard (adjust in a work out with the intensity feature).
I wouldn’t worry too much in your position, having done 2x ramp tests in total. Keep training through a few more blocks and see what happens.
If it becomes a pattern but you still prefer the ramp protocol to 20min test, just adjust up a bit each time and go from there.
Also masters 55+ age and have seen odd results from ramp test when FTP is at high % of vo2max. By odd I mean ramp test will put FTP below 200 but I can do sweet spot work at FTP setting of 230W (roughly 88% multiplier). But more than half of ramp tests gave reasonable results using 75% multiplier.
Switch to a longer test like 20-min or perhaps 8-min. Each FTP tests has its own pluses and minuses. Better to use one that is more likely to give consistent results than play around with % fudge factor.
