I completed the prescribed “Brush” workout at RPE “hard” that it expected me to find either hard or very hard. No pauses or interruptions. Why am I only getting 3.4 / 3.9 completed for threshold, and 5.3 / 5.6 for sweet spot?
What trainer are you using?
It looks like it’s a bit slow to react in ERG mode and also placed you slightly low on the “under” sections of the intervals.
I.e. the overs look a bit narrow and slopped and there seems to be a bigger gap between the unders and your FTP line than the target of 98% would suggest.
I think the lower score is probably right but frustratingly you didn’t do anything wrong - looks like your trainers ERG mode has sold you short a little.
I wouldn’t worry too much about it though - it won’t effect your future training much if at all… just some numbers on your carer page that the AI doesn’t use anyway.
Did you do the workout in the TR app or on Zwift?
That was on Zwift, I agree with Kevistraining.
I know that Zwift is a little slow to react with trainer Erg mode.
Sometimes it good and other time you get dinged on Workout score.
This happens to me all of the time.
It can be frustrating but try not to sweat it, your workouts won’t be affected.
My results for that workout were similar when I did it in February (also in Zwift). Could be due to Zwift responding to power changes a little slowly. Could be due to incorrect ALs being assigned.
I’d be interested to see if others have the same experience with this workout.
I’d also be interested to know if your Tempo score was as affected as mine
I have the workout score go both ways most of the times.
With Lion Rock -4 the power increase at the beginning and end of the interval Zwift just couldn’t keep up.
This season is the first time that I’m doing most of my workouts on Zwift and from I’ve learn when it come to workouts with a lot of short changes it’s better to do it on the TR app.
On/off Vo2 and Anaerobic style workouts.
I want to say Over/Under too but because of the longer overall style of those workouts, I’ve been doing most of those on Zwift and accept whatever WL it gives me, sometimes they do come out with the full score.
These where all done on a Kickr v5 using the direct connect
I had the same issue about 2 months ago, posted about it, and got the same responses seen today.
short answer…nobody knows.
I will tell you that I contacted TR support, and they analyzed my calendar and the specific workout in question, and replied that it is a bug in the system, and it will have no affect on my training moving forward.
that’s all I’ve got
@Caro.Gomez-Villafane would you be able to have someone look into the Brush workout to see if there is an issue with the ALs, as noted above?
Yes
I will take it to the team!
@bsladics is correct in that this is a visual issue that our team is aware of and that we’re actively looking into. Future recommendations are not negatively impacted by this.
I wonder if the ERG mode power smoothing might cause the power to be slightly below the targets. I run without the power smoothing and generally end up with workout levels at or above for the main zones. The other posters in the thread also seem to run without power smoothing.
I think it might be that Brush is missclassified as a 3.9. It looks easier than Wheel which is a 3.6.
Not in my particular case. I have far more erratic power in VO2 Max workouts and have no trouble both meeting power targets and receiving full “marks.”
That’s a brilliant explanation. I have to agree it’s simply mislabelled, and the points I am getting are reflecting what Brush’s workout levels should actually be.
That said, the workout level label isn’t actually used by TR in any consequential way, so this appears to be a cosmetic issue. Training feels like it’s still well on track.
