What are the benefits from losing body fat
Okay, losing body fat is obviously increases w/kg and somewhat w/CDA(probably) , but what are and how significant the matabolic, cardiovascular and other benefits from going for example from 20% to 12% body fat?
Visible abs.
Idk theres no sounds, only a judgmental look ever since he found out the price tag of my new sir velo
You can see the impact on climbing with a simple calculator here:The Broleur Hill Climb Calculator
The calculator (in my opinion) shows watts a bit low, but the comparison can be helpful.
  • Baseline at current 183lb, it takes me 235w avg to do this climb in 10 min.
  • If I lose 10lb, it takes me 10 less watts to cover the this climb in the same time.
  • OR at the same 235w, i complete the climb in roughly 23 less seconds.
Depending on body composition, I think if you’re %20+ bf or have a bit of extra weight (myself) you’d benefit greatly from losing body fat as performance likely wont take much of a hit during that process.
Once you get to a relatively lean weight and start to try to get lighter, performance will tank. We see lots of TDF riders increasing weight in favor of putting down more power, as the w/k calc just works out better.
https://clinmedjournals.org/articles/jowm/journal-of-obesity-and-weight-loss-medication-jowm-9-048.php?jid=jowm
20% is right in the middle of the healthy BMI range for men. 12% is not in the healthy range - take that however you want.
I think that once one is in the healthy range, diet and lifestyle matter way more than a few percent of body fat either way.
If one is chronically under nourished to maintain 12% then it’s not going to be healthy.
As they say, your mileage may vary. 20% is still in range.
Google:
For men
  • Body fat: 20% body fat falls within the “acceptable” range for men (18-25%). It is considered a healthy and fit physique, though muscle definition may not be as pronounced as in a leaner man.
  • BMI: A BMI in the healthy range (18.5-24.9) is possible with 20% body fat, but it is not a guarantee
I still stand by what I said. At a certain point, diet and lifestyle is probably more important to health than percentage of fat. You can have someone with 20% body fat who exercises and eats a healthy whole food diet while you can have a person with 12% who smokes, drinks, and has a diet of cheetos and soda.
I’m not disagreeing with any of that. I still think lifestyle and diet and whether you exercise is more important than 8 percentage points which was the original question asked.
What’s crazy is that most top cyclists come in at or below 10% body fat, even without all that upper body muscle to help push the number down.
And less bone as well. Was looking at the literature recently and BMD for cyclists is about at the level of a sedentary person, sometimes less.
I doubt I’ve ever hit 12%, but I’ll swing between high teens/low 20’s in the winter and down into the mid teens when I’m really fit during the season. That’s based dexa scan numbers and it’s been a few years since I did one (and I’m getting into my late 50’s, so maybe not getting quite as lean as I used to). Obviously, there is the power to weight benefit of not carrying extra dead weight around, but I also see my best raw power numbers when my body fat is the lowest. I always wondered if maybe fat carried a metabolic load or reduced aerobic efficiency, but I researched a bit at one point and couldn’t find anything material. Every pound of fat does carry a small metabolic load (just maintaining the fat actually consumes some calories every day), but I couldn’t find anything saying fat reduces aerobic output on an absolute basis. So, carrying extra fat will reduce your VO2Max (because it’s a function of body weight), but will not reduce your maximal O2 uptake. My conclusion is that the correlation between my lowest body fat % and my highest raw power output is primarily a byproduct of those things both happening at the peak of my training during the season (duh).
Anyway, that’s what I found in my research, but I only did some basic googling. I was surprised that I couldn’t find much showing the benefits of body comp beyond having a better power to weight ratio. I mean, if you were carrying a bunch of fat, I’d think you’d at least have cooling challenges that would reduce aerobic output, but I didn’t find any studies saying that. Seems like common sense to me, but maybe it’s just bro science. I know I ride better in the heat when I’m leaner, but again this is typically happening at the peak of my season (and a hot part of the year) , so maybe the BF has little to do with it.
Ability to shed heat. When I was lean (it’s bean a long while, but I remember :-)), I was able to perform even in high temperatures. Now that I’m porky, I overheat quite a bit easier. I suppose 50 pounds of extra mass, mostly fat, will do that do a person :-).
I was going to add this. It’s not listed as an advantage very often but it is a large part of my personal experience. I think it’s legitimate and not just memory of how good you used to be, as it’s very noticeable with fat changes in both directions!
