Unbound Gravel 2023
What are people planning on carrying for on-bike repair stuff for the 200?
Well I am out. My injury has kept me off the bike past 4 weeks, I see the doctor next week.
Enjoy it everyone, hoping I can defer to next year
@ABG Sorry to hear this. I hope you can defer and crush it next year.
Tire boot
Bacon strips
Inner tube patch
Chain quick links
Multi tool which includes chain breaker
2 inner tubes
Mini pump
Electrical tape
In Osprey
Zip ties multiple sizes
extra links of chain, master links and link tool
bottle of lube
Frumpa pump
silca mini pump
Alien multi tool
CO2 x 2
mud stick
chop sticks
dyna plugs
extra 2032 batteries
Garmin InReach Mini
Small roll of gorilla tape
Emergency spoke
Silca Gear wipes
spare presta valve cores
Chamois cream packets
pain killer
Imodium
Tube of electrolyte tabs
extra calories (bars) in case the day gets longer.
quick clot compress (i’m on blood thinners, so these aren’t optional.)
in seat pack
2x tire boots
2x tubes
patch kit
levers
Has the smart drink worked well for you? I haven’t really tested it out. I’ll have 40g carbs in my bottles then aim for a couple of gels or skratch chews to get me to in the 80-100g carbs per hour range. Waist hydration pack will have water but may add some nuun tabs to that
It’s like freaking magic. First time I used both Eat and drink in combo was a self-supported century during lock down. I was rolling home at 107 miles and felt like I had another 20 in my legs because I was hydrated and fueled.
Eat doesn’t work as well for me now since it prompts for calories and I’m trying to stuff in 90-120g of carbs in. I try to start with solid and work my way from there to block, gel, liquid, but depending on the ride/race and where I am, there are times when the only option is to grab for the bottle of carbs and take a swig, but I don’t start with liquid. It really is my last resort, bottom of the barrel, final leg, I don’t want to eat anymore but I need fuel, option, because I KNOW I can drink something as innocuous as Maurten or roctane drink.
Actually 50/50 Maurten & Roctane Summit Tea has all the carbs and just enough of a different taste that I can use it even when I’m tapped out. I’m going to try and do a DIY mix using some instant black tea or jasmine tea I found on the interwebs. WAY cheaper than either of the off the shelf, but I better get crackin because there really isn’t a lot of time left to experiment & validate a ā€œnewā€ DIY mix as April starts next week.
In the past I’ve tried on carbs in a bottle but at times it felt like I was just forcing myself to drink when I didn’t want to especially in cool weather. Hence switching to fewer liquid carbs and use gels in solids to fill in the rest. Gives me a little more wiggle room if I drink enough. But if it’s warm at unbound like most years drinking won’t be an issue.
I have these also, as I’ve read that they are among the best plugs for sealing a tire quickly.
I have had poor results with bacon strips, and the Stan’s dart was completely worthless (couldn’t penetrate through the hole in the tire; the plastic spindle broke; the black fluffy things ripped off).
One concern about the Dynaplugs is if you need to put a tube in after the plug, you’ll need to first extract the plug as otherwise it will puncture the tube. So the Dynaplugs better be good at plugging the tire!
I haven’t tried stan’s dart, but I like the dynaplugs. I carry bacon strips also, but only used for longer cut where a dynaplug can’t fill the entire hole. Sometimes takes multiple strips to make it work (at which point it’s sometimes faster to boot/tube it.
I’ve actually had great experiences with the Stan’s Dart, but I also carry bacon strips and a dynaplug.
I’m sitting here trying to decide if I bring a whole ass spare tire with me on the XL, seems like it’s a fairly common thing for folks to do
I had a spare at each drop bag, but I only did the 200. I do carry the parks tool sidewall patches with me incase of a major blow out, and hope I can make to the next drop zone. The XL is a whole other beast of a ride so I don’t know if that is practical.
We have been debating this as well. On the one hand it seems like overkill given the experience so far in the 200 (KNOCK ON WOOD), but it would also suck to DNF because of a tire failure. In some ways it’s not that different from the 200 where very few (if any) people carry extra tires.
Have you ever been on a bike ride where you needed to replace a tire? I never have. I’ve replaced tires after a ride, but was always able to fix things during the ride with plugs/tube.
There’s a saying used in backpacking/mountaineering - ā€œyou pack your fearsā€. If I was riding the XL, I wouldn’t bring a tire.
Taylor Lideen who’s won the XL brings a spare and also runs Maxxis Rambeler’s with silk shield. I think he used his spare in one of his wins.
47mm pathfinder pros mounted. Measure 46mm wide right after mounting.
6mm clearance at the rear chainstays. Clearance at front fork not an issue.
I’m going to ride later today on them. I expect them to feel nice and plush!
Rode the Gravel Course for this year’s Sea Otter on the highly discounted IRC Bokken Double Cross 42mm yesterday. Good gravel tire, but not a great Fort Ord tire. Needs more side lug for the highly packed but can be loosened sandy terrain.
How’d you like them/ what tire pressure did ya run? I have yet to set mine up as I want to keep ā€˜em as new as possible before the flint hills, but I’ll probably install them at the end of the month
Ran them on a set of Head GC3 Performance wheels at 26 up front and 29 out back. Only felt too soft on some larger XC type hits. Felt stiffer than GK SK+ 43mm
I’ll probably take them off and put last year’s SK+ on for training.
Im set on running SS+ on HED Emporia Pro wheels for race day.
Started at 30 psi. Higher than I’ll run them, but I had just put them on earlier in the day. Will drop a few psi and see how they feel in subsequent rides. Even at this pressure, the tire felt more plush than my previous 38s. Definitely will be running these for unbound.
