Trying to understand AI prediction
Of course! I sure would like to know why I work hard and lose watts. And yes, I am recovering.
Yup, that’s pretty accurate. It would be wise to dump that part and keep the confusion down. And, who is Nate? :wink: Seems so long since he’s been around and it’s obviously a negative for me. The podcast has turned into such a boring worthless venture I start it and then stop as Jonathan gets so into metrics and when real athletes try to speak or contradict, he finds more stats. Sorry, but stats obviously can be skewed and make a horrible podcast. As a triathlete I feel like I’m wasting my time with TR.
There’s a bug in zwift workouts too but TrainerRoad is slow to acknowledge it.
I raised this a number of times on this forum last April but was told ‘no, it’s only an outside bug’
I’ve asked the TR rep here a couple of times to confirm it’s a known issue now but have been ignored.
Lack of openness about known issues is not a good sign imho.
I feel like I recently saw one of the staff admit it wasn’t only outdoor rides, but I agree it was slow to come and I can’t remember who or where.
Agreed that yes it’s been mentioned in passing, but there’s no sticky post saying ‘beware the zwift bug’ So unless you’re deep in the weeds on the forum here you’re oblivious.
There’s so much unexpected and unexplained app behaviour reported here by confused users. TR comes with plausible explanations: “It looks like…” or “It might be…” etc but, in truth, they cannot look inside the black box they have built with AI, and are just taking educated guesses.
It would be interesting to see a user manual at this stage on how to use the app given there seems to be so many differ.ent workarounds recommended in so many different scenarios.
I think that TR is running an experimental release on users and trying to manage the fallout here. it’s all a bit unethical in my view which is such a shame from a company that had my highest regard in the past.
And 30s AFTER
Good job this statement was not a serious one :smirking_face:
Not really, the NP for the next period includes 30 seconds of normalized rolling power data from the previous period. There’s no lookahead into the following 30 seconds. It’s not obvious how best to fix this given the definition of normalized power. Technically normalized power is not even defined for the first 30 seconds of a period. One approach would be to zero it out at the beginning of the next period and not include any data from the previous period at all (ie. let the rolling window fill up to 30 seconds worth). But the usual approach is to not worry about it.
Edit - you could also argue that the last 30 seconds of data in the period is not “represented” in the NP as much as the earlier data in the period.
Exactly so up to 30 seconds AFTER the interval has finished, the power data is still feeding NP.
Yes, but it is feeding NP that is reported to the period after the interval.
For example, f you have a rest interval A, an intensity interval B and a rest interval C:
  • The last 30 seconds of A bleeds into B
  • The last 30 seconds of B bleeds into C
  • B does not bleed into A
  • C does not bleed into B
In pictures for a 2 minute interval at 347W …
A bleeds into B:
Select B so as to avoid bleed from A:
Just the first 30 seconds of B to show the worst case bleed from A:
C does not bleed into B:
B does not bleed into A:
B bleeds into C:
Interestingly, TR is not even self-consistent here. Check out the view of the workout (not the activity) - no bleed through so the NP calculation is building up the 30 second rolling window not carrying it over. :man_shrugging:
It looks like you haven’t updated your FTP since May 15th. Is that right? Maybe that’s part of why you’re seeing a change predicted for tomorrow.
Another thing I’m seeing is that you regularly do 0-1 hard workout a week. I think getting up to two hard workouts a week consistently would help a lot. Consistent training is probably the #1 way to build fitness.
Also, you took 22 days off in September, which is certainly playing a role here.
Let me know if this helps and if you have any questions. :+1:
Thanks for the reply. The reason I didn’t update the FTP is that the AI suggested an FTP that was FAR below the FTP I just did via an FTP test. Even keeping the higher FTP I had no struggles doing any of the prescribed workouts. I also was doing more volume, up to 6 or 7 rides a week, so much more than TR had suggested. (our weather was wonderful here, so took advantage). I did take 3 weeks off after season but that should have no bearing on my FTP going DOWN after starting the FTP build program weeks later, in fact I should be fresher. As far as the hard workouts, I did what the plan suggested and continually see my FTP going backwards. It’s so frustrating as this has happened more than once. I have no confidence in the plan builder. As a certified coach, I was boing last and allowing the TR plan to take effect. It looks like I’ll now write my own plans as the “test” to see TR results was not a good one.
Do you think that tomorrow’s predicted FTP is reasonable? Based on your recent workouts it looks pretty solid to me.
It’s a four watt drop from where you’re at now (set in May), but based on what I said in my previous post along with the fact that you’re not consistently following a TR prescribed training plan, I don’t think that’s unreasonable.
Let me know if you think there is something else at play here. I’d be happy to chat some more.
There should be a tool to track user compliance to the plan…looks like it will help in many cases.
Maybe it already exists.. :face_with_monocle:
Actually I think an increase is more legit than a drop. Oddly, the chart you posted shows a drop by doing the trainer road plan. After the break I had, we see a huge improvement upswing. To me, that would indicate a raising FTP, not one dropping. Maybe I’m not seeing that right, but more volume should see raising fitness as long as it’s not too fatiguing and recovery is good.
If you refer to the “TSS tr actual vs planned” from TSS chart I imagine more of percentages like a bigger window to point it simply “ user compliance 85% to the plan”. :smiling_face:
with regular App notifications… “Its recovery week, what are you doing!!! Get off your bike!!!” … or …"it’s past the workout start time.. are mixing your bottles?! LFG!!! "… "You are down to 98% compliance, LOCK IN! " lol
I definitely wouldn’t recommend an FTP increase based on your last few hard workouts.
The last one was on the 17th where you rated a level 2.0 threshold workout as hard.
The week before that you rated a level 2.8 sweet spot workout as very hard. Earlier that same week you rated a level 2.6 threshold workout as very hard.
Raising your FTP will likely be counterproductive right now. Lowering it would give you more productive workouts.
Let me know if that makes sense and if you have any other thoughts or questions.
First off, the evaluation method is really wonky. I am pretty surprised you don’t use a 10 point BORG scale instead, as that would be far more accurate in determining perceived exertion and is pretty much the standard. Differences between moderate, hard and very hard are really not a thing that has much validity. As stated before, I just did 7 weeks of AI suggested workouts (actually twice within the last 2 years) and what was the result? A DROP in ftp on the “FTP builder plan”. Perhaps I don’t understand the logic in lowering my stated FTP as that would give me easier workouts. I kept a higher than suggested FTP and NEVER failed a workout and I did all that were given to me by the plan. You stated I only did 1 VO2 workout per week, but that was all that was given by the “plan”. I’m very good at following what is given, though often I extended the cooldown to get more aerobic volume. Many of the podcasts stated that doing so would improve fitness, so when I found time I did that.
I’ve loved TR and have been there forever, but my FTP has been stagnant despite following plans. I did not follow your tri plans as they are simply not worth doing as they stand now and have been through the years. I’m on a yearly plan that just renewed. Am I able to cancel and get anything back, or am I in for the year? I’d like to go a different direction as what I’ve tried has been fruitless. Thanks so much!
