I may get roasted for this, but as a triathlete who trains 10-15 hours per week, I’m struggling to effectively use TrainNow.
1. I get about 2-3 yellow days per week every week. This wouldn’t be a big issue if not for the fact that TrainNow on a yellow day will only give me endurance workouts. I wish there was a way to override that and select a threshold/sweet spot workout. Instead, I just manually select a workout. I’m not sure it’s set up properly for the reality of triathlon training. Unfortunately, triathletes need to train hard on yellow days.
Other times, TrainNow recommends oddly difficult workouts. I did a race yesterday where I rode for an hour and set a new 1hr power PR. Today when I select 90 mins, TrainNow’s first recommendation is threshold over/unders. That seems incorrect.
Yes, train now gives me nonsensical recommendations the majority of the time. Then on a yellow day it gives a harder endurance day, and one time i followed it and it then decided i needed one more yellow day. It still recommends that same workout on a yellow day.
Yes, when TrainNow fails to do what I want, that’s what I do, I go to AI Workouts → Category. However that’s a bit more cumbersome, it requires to me to select the specific workout type (eg. VO2 Max on-offs vs VO2 Max traditional), and it also requires me to “schedule” it, eg. I can’t just load it immediately without first adding it to my calendar.
Here’s an example of where I desired to do a high intensity workout on a yellow day. The prior day was run/strength/swim. There’s no way to “rate” those workouts to my knowledge.
Hi Eddie, we discussed this back in August when it happened. It recommended Leavitt-5 which is a minus of a tempo workout, not what I’d call an ideal yellow day workout. What’s not shown though is on Tuesday, it recommended another similar ride of around .7 IF. If I have a scheduled workout on my calendar, I don’t get a suggested workout so I don’t know what it would suggest now but I’ll often get this sort of suggestion on the same day I log a run if I don’t already have the next ride in the calendar.
No, as they’re quite random. I pick my own workouts from the library. It is to be understood somewhat since I’m not telling the system which days I want to do specific workouts. I really found it odd when during a yellow day it had repeatedly picked a workout that fatigue detection then flagged as harder than suggested. Does train now take in to consideration fatigue status or not?
Sorry, I thought i had responded above. I don’t pick train now for any workouts as I don’t agree with the suggestion. The one time I did decide to pick the train now workout, fatigue detection agreed with my intuition.. it was harder than what I should be doing that day and extended my yellow status by another day.
I don’t do a plan since I haven’t seen one that fits my individual targets as a multi sport athlete. I’m following a 14 day cycle, and moving workouts every other week isn’t easy with the mobile app. I haven’t used the desktop for 5-6 years.
I ran this morning and it is suggesting hard start threshold if i choose to do a double. Train now is advertised as picking the right workout and an option for those who aren’t on a plan.
What does TrainNow give you if you load it up right now?
Is the issue most closely tied to TrainNow not considering running and other activities?
You can and should add RPE to non-cycling activities. That should help us understand how you’re feeling a bit better. As a runner, I understand the difference between easy and hard runs. What was the effort of yesterday’s run?
Personally, I would agree that the TrainNow AI workouts seem a little ‘suspicious’. Yesterday I had a 2:15 endurance ride, and today TR fatigue detection has put a yellow day on my calendar. Fair enough. But if I look at TrainNow the suggestion is for a 2:30 endurance ride, which seems odd. Could I do it? Certainly. Would I then like be not well recovered for the 90 minute Sweet Spot session on the calendar for tomorrow? Most likely.
Basically, suggesting a 2.5 hour ride as an alternative for a recovery day seems a bit odd.
What type of activity does TrainNow consider when making a recommendation, and how far does it look back?
TrainNow will recommend workouts based on your recent TrainerRoad workouts and non-structured indoor/outdoor riding. It’s important to note that while TrainNow will look at your most recent workouts when making a recommendation, it does not consider periodization or other factors. For instance, it will not recognize if you need a recovery week. If you are looking for that type of structure and periodization, we recommend using a training plan.
Does TrainNow account for fatigue?
TrainNow bases its recommendations exclusively on your relative abilities in each training zone, determined by your success in recent workouts. It does not consider periodization or fatigue on its own. If you today is a Rest Recommended day or Avoid Intensity day though, you’ll only see recommendations for Endurance workouts or rest.
Is TrainNow making recommendations based on what’s ahead in my calendar/Plan Builder?
TrainNow is a day of tool! It uses recent training history and data to recommend a workout for today. It does not consider periodization or fatigue (except for how Red Light Green Light affects recommendations) and will give the same suggestions regardless of whether or not you’re following a structured training plan. This is why we recommend TrainNow primarily for athletes who like to supplement unstructured riding with occasional structured workouts. It’s not intended as a replacement for a training plan.
Unless I’m mistaken TrainNow doesn’t recommend a duration of the workout, you have to select that yourself. Perhaps the last time you used TrainNow you had the duration set to 2.5 hours? And that’s why it was picking one this time.
I couldn’t speculate on that, as I’ve never actually used TrainNow. I was just checking to see what it showed me today, based on the OPs comment.
And I’m still trying to process the response from @eddie , as it seems (to me, anyway) that TrainNow should take into account whatever else it can see on a rider’s schedule. To me, TrainNow ought to be a feature for ‘I don’t have anything on my schedule for today, but I feel like riding, so give me something that fits into the overall picture.’ I don’t think it should just be ‘based on what you’ve been doing, we think you can handle this.’
