Training Schedule Advice
Hi! I could use some help figuring out how to schedule my training and have a few questions. I work 4/10’s so my availability for riding is:
Mon - 1-2 hrs
Tues - 30-45 min
Wed - 30 min
Thurs - off
Fri - 30-45 min
Sat - 3-4 hrs
Sun - off
Right now I have this set up as:
Mon - 90m hard intervals
Tues - 45 min endurance
Wed - off or 30 min endurance or strength
Thurs - off
Fri - 45 min hard intervals
Sat - 3-4 hrs endurance
Sun - off
I’m trying to prepare for three days of crits next July and am expecting a baby in early Feb, so I’m doing an FTP plan now till Feb, then whatever I can, then start a crit plan in March. But I also have been enjoying Zwift racing, so I’m joining a team and doing ladder racing, which would probably be either Mon, Thurs, Fri, or Sat most weeks.
There are a couple things I’m thinking about changing:
  1. Trainerroad has me generally doing VO2 on Mondays (90m) and over-unders on Friday (45m), I recently swapped those, thinking doing a longer over-under/threshold workout on Monday is more valuable and then shorter 45m VO2 on Friday. Does that seem right?
  2. I’m not totally sure where to fit Zwift racing in, which workout it should replace, whether I should do it every week, if it should generally go on Mondays alongside some more outdoor riding at z2, or more workouts after the race. Are there any good guidelines for this?
Below is what I have set up so far for a typical week in an increase FTP plan:
Really appreciate any advice! Thanks!
I will not comment on your schedule much,but it looks solid for your availability. About plans in march after baby comes to the world you will adjust it if needed. Take week or two off to help and talk to your partner about training, give her needed free time. Training may be different it all depends on baby sleep schedule and how much it sleeps during the night. Recovery may be more problematic. My advice is got get as much as you can from training before baby comes after that everything is uncertain. Every case is different. Crits involve a lot of skills. Is it your first time doing crits? If yes, can you practice in some races before that?
Thanks! Yeah definitely everything after the baby is up in the air for now haha. That’s a good reminder. Might not even race depending on timing and baby’s temperament and finances. But assuming that all works out, yeah I’m hoping to do a couple local crits for practice in April-June. I have a lot of experience racing crits, but haven’t done them in a while so I definitely need to get the pack skills back.
How does a week in your build and specialty phases look like?
I’m already in the build phase so that’s what the screenshot above is from, and then this is the specialty phase:
I’ll likely move the workouts around again when I get there, weird that it changed the order.
You’re running a pretty traditional schedule just one day shifted from most people. Can’t see anything wrong with that.
However…
If you’re doing a Zwift race every week I would seriously consider scrapping one of your intensity days (either Mon or Fri). That’s a lot of intensity for the week; races tend to blow you out of the water for a couple days and make it hard to absorb any training stimulus. You might find yourself in a hole over time.
That makes sense, the race would definitely replace one of the days, but maybe for the first few races I’ll also scrap the sweet spot and see how it feels with just 2 days of intensity first.
