TrainerRoad Ramp Test - ERG mode - broken? (Video included)
Don’t shift in ERG. If you want a slower cadence, you simply slow your legs down. This ends up dropping power below target. The trainer will react to hold the power target by increasing resistance.
If you want to pedal faster, you have to push harder (which overshoots the power target) and get you your desired cadence. The trainer will then reduce resistance to hot the power target.
I honestly think most of your issues came from a misunderstanding of ERG and what you need to do to make it work well. It’s like any other tool and works as designed, but it must be used properly and as intended to get the right results.
Great videos. Ty for sharing!
First one was very informative.
Should i not use power match for ramp tests?
I can’t answer the PowerMatch question. There are people who like it and others that don’t.
Ideally, it makes sense to use so you are using the same basic power meter data inside and outside. But enough people have had issues that I don’t see it as a perfect solution in all cases.
Sadly I have 3 bikes with 3 different power meters, and then the wahoo.
My crit bike has a dzero
My road race bike has a single sided stages
My aero road bike has a dual sided stages.
I’m a mess.
I’m in a similar boat with 3 power meters and 5 smart trainers :wink:
You are a mess indeed w/3 bikes and 3 diff power meters :joy: #firstworldproblems
I have used Powermatch since day 1 with TR. Initially it was a first gen Kickr back in the day. Nowadays, it’s with a Neo. The bikes all have Power2Max. Over 4yrs now and I can count the number of ERG issues I’ve had on one hand. +1 for Powermatch !!
You stated you like 95rpm. Well, when you retest, settle in at 95rpm. Remember, if you let the cadence drop, ERG will increase the resistance. If you let the cadence drop too much, you enter what is called the spiral of death where the ERG keeps adding resistance and you are unable to generate the power at that low a cadence. Boom… game over. The opposite is true w/increasing the RPM and ERG reducing resistance, but this is hardly, if ever, a problem that anyone has ever complained about.
Is it normal that the power output isn’t the same as the ERG prescript ed power ? As in: your wattage is all over the place. While ERG should hold your power constant? Or has this to do with the powermatch features?
My ramp:
Ur ramp:
Your ramp is an artificial representation of your power (ie: smoothing). It is probably impossible for someone to hold their power output that close to the target power. This is more typical:
If you have a Wahoo trainer, watch this and change the setting to turn the smoothing OFF.
Ah, the ole spiral of death. I’ll never forget my first erg mode ride and the 4 or 5 after it. I was in zwift doing a workout for the first time. Power target went up and almost instantly i felt like my trainer and legs got dropped in a vat of cement. I had no idea what happened or why. After that I realized that you can’t let your cadence dip without being on top of the resistance you are pushing. For the next few workouts I couldn’t understand why erg mode was forcing my cadence to go faster and faster. Eventually it clicked that I was doing that, not erg. I was chasing the power target rather than setting a cadence target and letting ERG mode adjust the resistance. You have to trust the trainer to manage the power. You just need to keep pedaling at the right cadence for you.
I use power match all the time, no issues on the ramp test. As @mcneese.chad says, Erg requires you to stay on top of your cadence to work properly. In my experience, I generally find that I have to pay much closer attention to cadence instead of power in Erg. Power takes care of itself in all but burst circumstances.
This simply looks like you entered the death spiral - maybe you didn’t know you were dropping cadence, but as cadence drops, resistance ramps up, and it can get ugly fast.
Woe is you guys. :roll_eyes::laughing:
This is my biggest single recommendation for ERG use. Ignore power, watch your cadence and do your best to keep it very steady.
Less fluctuations of your cadence will yield a smoother and better ERG experience. Only change cadence when you want to do so. You are responsible for that, not the trainer.
During my second ramp test, i’ve noticed the cadence ramped along with the power output. Is this a bad thing or is this just my natural cadence with higher powers?
I concur with the above posts that this is probably an issue of the user allowing ERG mode to maintain target power despite growing slips in cadence.
I disagree, however, with this assertion: “If you let the cadence drop too much, you enter what is called the spiral of death where the ERG keeps adding resistance and you are unable to generate the power at that low a cadence. Boom… game over.”
If you let the cadence drop, keep up the pedalling pressure and shift gears to establish a higher cadence, and the resistance will subside to maintain power at the new cadence. With practice, one will learn to avoid this avalanche of slipped cadence and unsustainable resistance load from happening, but even before this skill is learned, it’s not strictly game over for the newbie. Shifting in an interval, after a surprise change in load and cadence gives the rider another chance to hit the new target.
With further practice, in addition, one can learn to employ an “unsustainably high” cadence in erg mode to prompt an erg mode decrease in resistance load, in anticipation of shifting to a harder/higher gear, thereby managing the bike’s chain position on the cassette and preserving the ability to recover from accidental or temporary slips into a “too low” cadence.
It’s a “bad thing” if it’s not what you intend to do. People need to take an active roll with ERG, especially in the Ramp test. You need to choose a cadence to hold and attempt to hold it the best you can. DO NOT be passive and allow the test and trainer to control you.
That is all true up until the final moments of the test, when you begin to really fail. In many cases, that shows as cadence sliding downwards to the point that you can’t turn the pedals over any faster than 50-70 rpm. If you hit that point and can’t return to a higher and desired cadence, you are done and have completed the test properly.
Maybe it’s appropriate to alter cadence throughout the test, but I think the intent is generally to hold your preferred cadence within a tight-ish range (+/-5 rpm?) until you can’t hold that any more. We do usually work on applying higher cadences as we get above Threshold in most workouts, but this is different in my eyes.
In any event, whatever cadence and trend you have in a Ramp test should be repeatable. If you don’t do the same thing each and every time, you are introducing variables that are likely to alter the results and what can be learned from the test. It seems holding to a single target is easier to shoot for vs some sliding rpm (up or down).
I see shifting as a crutch, and one that should not need to be employed in a Ramp test.
  1. Most people watch the test and can see the steps coming, so it should not be a surprise when the resistance increases.
  2. The steps are 6% of FTP in each and every case, so it is a small change and one that can be anticipated each time.
  3. Even if you do “blind” Ramp test like I do (with all the information hidden except cadence) you can still react to the resistance increase without major interruption to each new step. It may pull you down in rpm a bit, but you have to react and get back up to the desired cadence with deliberate effort.
    • Blind testing seems rare at this point, so I don’t think #3 is an issue for many riders.
Additionally, if people use shifting to get over a hump, they SHOULD be returning the bike to the prior gearing once they get on top of the effort again. If not, they are likely to be altering the flywheel speed during the test. (I couldn’t really tell from your recommendation if you were suggesting a return to the “start” gearing?)
There is debate about the impact of that change and what it means to the FTP derived from the test. I am fairly certain that it does have a realistic impact, especially if the change continues in one direction only in the test. Maybe it’s a non issue if the person repeats the shifting trend in all future tests, but it is yet another variable (like the sliding cadence discussed above) that may alter the results of the test.
Keep in mind that tests like this rely heavily on the repeatable nature of the test. We should do our best to match the conditions of the test (room temp, humidity, fans, rider position, bike gearing and more) so that we can compare results from one test to the other. That may not be important to everyone and all they care about is finishing the test and getting an FTP number. But it may well lead to training issues if they end up with variability from one phase of training to the other.
Excellent information everyone.
Ty so much for the lessons and pointers.
Going to give it a week and redo the test next Tuesday. I’ll do all my TR workouts in erg mode this week for practice.
I usually consciously drive my cadence up as power increases because generally my cardiovascular system can handle the stress of those higher loads better than my legs can. My legs are usually the first thing to give out on a test, so spinning at a higher cadence unloads them a little bit allowing me to stick it out longer. In VO2max work, it’s not uncommon for me to spin at 110rpm, whereas my general comfort zone in other workouts isn 95-100rpm. This also carries to the road where I’ll operate anywhere between 90 and 120rpm.
So it’s not a “bad” thing, it may just indicate where your strengths and weaknesses lie.
I’ve got a cheap smart trainer (Tacx T2240 maybe?) and find that you need to be in sort of the ‘right’ gear for the desired power. During the ramp test, I typically need to shift up once. However, I know that its going to run out of range, so try to shift before the business end of things.
Its also often sluggish to react to changes in cadence, and it can take up to 20s of steady pedalling to get it back on target. Sometimes a quick change down and up the gears gives it a nudge to adjust power.
To the OP, what I was going to suggest is to do a few workouts in erg mode, before attempting another ramp test. Just to get used to it. You probably have a rough estimate of your FTP anyway from Zwift that will do for a few attempts.
